P99
Defines
Classification
Meta_programming
The macros in this group help to classify different token sequences, in particular type specifiers that are composed of several tokens. More...
+ Collaboration diagram for Classification:
Defines
#define P99_BOOL_NORMALIZE(SEQ)   P00_TYPE_NORMALIZE(P99_BOOL_QUAL_LEN(SEQ), P00_BOOL_CLASSIFY(SEQ), SEQ)
 Normalize a Boolean type expression.
#define P99_FLOAT_NORMALIZE(SEQ)   P00_TYPE_NORMALIZE(P99_FLOAT_QUAL_LEN(SEQ), P00_FLOAT_CLASSIFY(SEQ), SEQ)
 Normalize an floating type expression, including _Complex types.
#define P99_HAS_NO_PAREN(...)
 Detect if the argument list has an extra pair of of () around.
#define P99_INTEGER_NORMALIZE(SEQ)   P00_TYPE_NORMALIZE(P99_INTEGER_QUAL_LEN(SEQ), P00_INTEGER_CLASSIFY(SEQ), SEQ)
 Normalize an integer type expression.
#define P99_REMOVE_PAREN(...)   P99_IF_ELSE(P99_HAS_NO_PAREN(__VA_ARGS__))(__VA_ARGS__)(P00_REMOVE_PAREN(__VA_ARGS__))
 Remove an extra pair of of () around the argument, if any.
#define P99_VOID_NORMALIZE(SEQ)   P00_TYPE_NORMALIZE(P99_VOID_QUAL_LEN(SEQ), P00_VOID_CLASSIFY(SEQ), SEQ)
 Normalize a void type expression.
Detailed Description
 All Data Structures Files Functions Variables Typedefs Enumerations Enumerator Friends Defines
