P99
A catch all 0-initializer. Variables of static storage are initialized as such as if all components recursively are initialized from 0. Use this macro here to achieve the same effect for unsigned a = P99_INIT; unsigned b[2] = P99_INIT; unsigned *c = P99_INIT; unsigned (*)d[3] = P99_INIT; unsigned e[4][5] = P99_INIT; Here depending on your compiler the last for |
1.7.6.1
