P99
signed p99_twos ( unsigned  p00_a) [inline]
Cast an unsigned type into a signed one as would do a two's complement representation of the signed type.
If the signed type is in usual two's complement this should be the identity. For other cases this is supposed to do the best possible.
Warning:
For bizarrely encoded cases this might result in a negative zero or so.
 All Data Structures Files Functions Variables Typedefs Enumerations Enumerator Friends Defines
