P99
#define P99_LENGTH_VA_ARG (   ...)    ((size_t)P99_NARG(__VA_ARGS__)), __VA_ARGS__
Meta-macro to generate calls to functions with variable argument list.
This supposes that the length is less than P99_MAX_NUMBER. It prefixes the list of arguments by an integer constant containing the length of the list.
See also:
P99_VA_ARGS
Definition at line 224 of file p99_args.h.
 All Data Structures Files Functions Variables Typedefs Enumerations Enumerator Friends Defines
