P99
 All Data Structures Files Functions Variables Typedefs Enumerations Enumerator Friends Defines
p99 Directory Reference
+ Directory dependency graph for p99/:
file  p99.h [code]
Use this to include all of P99.
file  p99_args.h [code]
Providing macros that handle variadic macro argument lists.
file  p99_atomic.h [code]
file  p99_atomic_arm.h [code]
file  p99_atomic_x86.h [code]
file  p99_block.h [code]
Macros that implement controlling blocks.
file  p99_c99.h [code]
C99 specific include files that are required by the standard.
file  p99_c99_default.h [code]
file  p99_choice.h [code]
Choice macros that implement `static inline' table lookup.
file  p99_classification.h [code]
classification of different types of token sequences
file  p99_clib.h [code]
file  p99_compiler.h [code]
Group compiler dependencies together in one file.
file  p99_defarg.h [code]
Macros for default arguments to functions.
file  p99_double.h [code]
Build decimal or hexadecimal double constants with macros.
file  p99_enum.h [code]
file  p99_for.h [code]
A prepprocessor for loop implementation and some derived list handling macros.
file  p99_generated.h [code]
automatically generated macros to handle variadic macros.
file  p99_generic.h [code]
file  p99_id.h [code]
Implement a simple FILEID that changes at each time this file is included somewhere.
file  p99_if.h [code]
preprocessor conditionals to use inside macros
file  p99_int.h [code]
Macros handling integer types and initialization.
file  p99_list.h [code]
Basis macros to process the parameter list of a variadic macro.
file  p99_logical.h [code]
macros to handle Boolean conditions at compile time.
file  p99_map.h [code]
macros to produce lists of statements or declarations.
file  p99_new.h [code]
Macros for initialization and allocation.
file  p99_paste.h [code]
macros that paste tokens in a predictive way
file  p99_posix_default.h [code]
file  p99_special.c [code]
This file just contains automatically produced information for doxygen.
file  p99_str.h [code]
Provide a family of functions str2XX that provide a safer end check with an position in the string instead of the bogus char pointer.
file  p99_swap.h [code]
file  p99_threads.h [code]
file  p99_try.h [code]
file  p99_tss.h [code]
file  p99_type.h [code]
file  p99_typenames.h [code]
Declare types derived from the standard types.
