P99
join a list with a specific token given as first argument More...
Collaboration diagram for Variable Length Arrays:join a list with a specific token given as first argument
Examples
P99_TOKJOIN(+, 1, 2, 3) -> 1+2+3 P99_TOKJOIN(., f(), a, length) -> f().a.length
Revert the argument list
Generate the quotient of non-negative decimal numbers A and B at preprocessing time.
Compute an absolute index in a multidimensional array with the same function as C would do that.
If we have N arguments after NAME, NAME must be an array of type
size_t NAME[N];
that hold the side lengths of an N dimensional cube. E.g
size_t const D[] = { 3, 4, 7 };
corresponds to a cube of side length 3 in dimension 0, 4 in dimension 1 and 7 in dimension 2, with in total 84 elements. With that, we get
P99_CDIM(D, 1, 2, 3) => ((3) + ((D)[2] * ((2) + ((D)[1] * (1))))) P99_CDIM(D, k0, k1, k2) => ((k2) + ((D)[2] * ((k1) + ((D)[1] * (k0)))))
1.7.6.1
