P99
#define P99_DECLARE_ATOMIC (   T,
  NAME
declare an atomic type that will use lock operations to guarantee atomicity
Normally it shouldn't be necessary to use this macro in user code for integral data types; the lock-free types should be detected automatically.
This is used per default for integral types that are detected not to support atomic operations directly and for floating point types.
Use this macro to protect your own particular data type.
Parameters:
Tbase type for the atomic type
NAMEthe name of the newly derived type. Usually for type foo you should use something like atomic_foo.
Remarks:
argument 0 of P99_DECLARE_ATOMIC should correspond to a type that is not a VLA.
argument 1 of P99_DECLARE_ATOMIC_LOCK_FREE must be an identifier
Definition at line 582 of file p99_atomic.h.
 All Data Structures Files Functions Variables Typedefs Enumerations Enumerator Friends Defines
