P99
Collaboration diagram for Decimal or hexadecimal double constants:Defines | |
| #define | P99_DEC_DOUBLE(SIGN, INT, FRAC, ESIGN, EXP) |
construct a double constant in decimal representation. | |
| #define | P99_HEX_DOUBLE(SIGN, HEXINT, HEXFRAC, ESIGN, BINEXP) |
construct a double constant in hexadecimal representation. | |
Since not all substrings of a double constant form a valid preprocessor token, construction of double constants must be done carefully when done with macros. The macros here guarantee that this is done in a portable way.
1.7.6.1
