Find a builtin type according to a code such as `ull' or `ld'.
E.g P99_BUILTIN_TYPE(ull) should expand to unsigned long long. The complete list for the 35 builtin types (+ required typedefs):
| code | type | is signed | signed | unsigned | integer rank |
| b | _Bool | 0 | | b | 0 |
| c | char | | hh | uhh | 1 |
| d | double | | | | |
| dc | double _Complex | | | | |
| f | float | | | | |
| fc | float _Complex | | | | |
| i128 | int_least128_t | | | | |
| i16 | int_least16_t | | | | |
| i32 | int_least32_t | | | | |
| i64 | int_least64_t | | | | |
| i8 | int_least8_t | | | | |
| j | intmax_t | | | | |
| ld | long double | | | | |
| ldc | long double _Complex | | | | |
| t | ptrdiff_t | | | | |
| signed | 1 | i | u | 3 |
| hh | signed char | 1 | hh | uhh | 1 |
| l | signed long | 1 | l | ul | 4 |
| ll | signed long long | 1 | ll | ull | 5 |
| h | signed short | 1 | h | uh | 2 |
| uz | size_t | | | | |
| u128 | uint_least128_t | | | | |
| u16 | uint_least16_t | | | | |
| u32 | uint_least32_t | | | | |
| u64 | uint_least64_t | | | | |
| u8 | uint_least8_t | | | | |
| uj | uintmax_t | | | | |
| u | unsigned | 0 | i | u | 3 |
| uhh | unsigned char | 0 | hh | uhh | 1 |
| ul | unsigned long | 0 | l | ul | 4 |
| ull | unsigned long long | 0 | ll | ull | 5 |
| uh | unsigned short | 0 | h | uh | 2 |
| v | void | | | | |
Definition at line 5304 of file p99_generated.h.
