P99
#define p99_strtou (   ...)    P99_CALL_DEFARG(p99_strtou, 3, __VA_ARGS__)
Default arguments for C99 function p99_strtou.
This macro is preferable to the atoi function. First, it is specific to unsigned and will return values in the correct range. Then, the default arguments make it functionally equivalent but add two features:
  • overflow handling
  • flexible p00_base, namely octal, decimal or hexadecimal conversion
This macro hides the function
 unsinged   p99_strtou ( char const *p00_nptr, char **p00_eptr, int p00_base )
See also:
P99_CALL_DEFARG
Parameters:
p00_nptris required
p00_eptrdefaults to 0, meaning that the successfully parsed string is not kept track
p00_baseis 0, numbers are hex if they start with 0x, octal if they start with 0 and decimal otherwise
Definition at line 340 of file p99_c99_default.h.
 All Data Structures Files Functions Variables Typedefs Enumerations Enumerator Friends Defines
