P99
#define p99_strtou64 (   ...)    P99_CALL_DEFARG(p99_strtou64, 3, __VA_ARGS__)
Default arguments for C99 function p99_strtou64.
This macro hides the function
 uint_least64_t   p99_strtou64 ( char const *p00_nptr, char **p00_eptr, int p00_base )
See also:
P99_CALL_DEFARG
Parameters:
p00_nptris required
p00_eptrdefaults to 0, meaning that the successfully parsed string is not kept track
p00_baseis 0, numbers are hex if they start with 0x, octal if they start with 0 and decimal otherwise
Definition at line 425 of file p99_c99_default.h.
 All Data Structures Files Functions Variables Typedefs Enumerations Enumerator Friends Defines
