P99
Data Structures | Modules | Defines | Typedefs | Functions
C11 thread emulation on top of POSIX threads
Emulating features of C11
+ Collaboration diagram for C11 thread emulation on top of POSIX threads:
Data Structures
struct  p99_tss
 A stub structure to hold a thread local variable if thread_local is not available. More...
Modules
 Thread_macros
 Thread_types
 Thread_enum
Defines
#define P99_DECLARE_ONCE_CHAIN(T)   extern p99_once_flag P99_PASTE3(p99_, T, _once)
 Declare the symbols that are needed for the macro P99_INIT_CHAIN().
#define P99_DECLARE_THREAD_LOCAL(T, NAME)
 declare a thread local variable NAME of type T
#define P99_DEFINE_ONCE_CHAIN(T,...)
 Define the function that will be exactly called once by P99_INIT_CHAIN(T).
#define P99_INIT_CHAIN(T)   p99_call_once(&P99_PASTE3(p99_, T, _once), P99_PASTE3(p99_, T, _once).p00_init)
 Ensure that the function that was defined with P99_DEFINE_ONCE_CHAIN has been called exactly once before further proceeding.
#define P99_MUTUAL_EXCLUDE(MUT)
 Protect the following block or statement with mtx_t MUT.
#define P99_THREAD_LOCAL(NAME)   (*(P99_PASTE3(p00_, NAME, _type)*)p00_thread_local_get(&(NAME), sizeof(P99_PASTE3(p00_, NAME, _type))))
 an lvalue expression that returns the thread local instance of variable NAME
Typedefs
typedef struct p99_tss p99_tss
Functions
int cnd_t::cnd_broadcast (cnd_t *p00_cond)
void cnd_t::cnd_destroy (cnd_t *p00_cond)
int cnd_t::cnd_init (cnd_t *p00_cond)
int cnd_t::cnd_signal (cnd_t *p00_cond)
int cnd_t::cnd_timedwait (cnd_t *restrict p00_cond, mtx_t *restrict p00_mtx, const struct timespec *restrict p00_ts)
int cnd_t::cnd_wait (cnd_t *p00_cond, mtx_t *p00_mtx)
void mtx_t::mtx_destroy (mtx_t *p00_mtx)
int mtx_t::mtx_init (mtx_t *p00_mtx, int p00_type)
int mtx_t::mtx_lock (mtx_t *p00_mtx)
int mtx_t::mtx_timedlock (mtx_t *restrict p00_mtx, const struct timespec *restrict p00_ts)
int mtx_t::mtx_trylock (mtx_t *p00_mtx)
int mtx_t::mtx_unlock (mtx_t *p00_mtx)
int thrd_t::thrd_create (thrd_t *p00_thr, thrd_start_t p00_func, void *p00_arg)
thrd_t thrd_t::thrd_current (void)
int thrd_t::thrd_detach (thrd_t p00_thr)
int thrd_t::thrd_equal (thrd_t p00_thr0, thrd_t p00_thr1)
void thrd_t::thrd_exit (int p00_res)
int thrd_t::thrd_join (thrd_t p00_thr, int *p00_res)
int thrd_t::thrd_sleep (const struct timespec *p00_duration, struct timespec *p00_remaining)
void thrd_t::thrd_yield (void)
int tss_t::tss_create (tss_t *p00_key, tss_dtor_t dtor)
void tss_t::tss_delete (tss_t p00_key)
void * tss_t::tss_get (tss_t p00_key)
int tss_t::tss_set (tss_t p00_key, void *p00_val)
Detailed Description
This is a relatively straight forward implementation of the C11 thread model on top of POSIX threads. The main difficulty in that is that the thread entry function signature differs between the two. C11 thread returns an int whereas POSIX returns a void*.
You find the thread management interfaces through the documentation of the type thrd_t.
Remarks:
In addition to POSIX threads this implementation needs some C11 atomic operations for initialization via call_once and status communication.
 All Data Structures Files Functions Variables Typedefs Enumerations Enumerator Friends Defines
