Include dependency graph for p99_atomic.h:
This graph shows which files directly or indirectly include this file:Go to the source code of this file.
Data Structures | |
| struct | atomic_flag |
| The "minimal" type for which atomic operations must be defined. More... | |
Defines | |
| #define | _Atomic(T) P99_PASTE2(atomic_, T) |
| refer to an atomic type of base type T | |
| #define | ATOMIC_BOOL_LOCK_FREE 0 |
| #define | ATOMIC_CHAR16_T_LOCK_FREE ATOMIC_INT16_LOCK_FREE |
| #define | ATOMIC_CHAR32_T_LOCK_FREE ATOMIC_INT32_LOCK_FREE |
| #define | ATOMIC_CHAR_LOCK_FREE ATOMIC_INT8_LOCK_FREE |
| #define | atomic_compare_exchange_weak(OBJP, EXPECTED, DESIRED) |
| Atomically compare *OBJP to *EXPECTED and set it to DESIRED if they are equal. | |
| #define | atomic_fetch_add(OBJP, OPERAND) P00_FETCH_OP((OBJP), (OPERAND), __sync_fetch_and_add, +=) |
| Atomically add OPERAND to *OBJP. | |
| #define | atomic_fetch_add_conditional(OBJP, OPERAND) |
| #define | atomic_fetch_and(OBJP, OPERAND) P00_FETCH_OP((OBJP), (OPERAND), __sync_fetch_and_and, &=) |
| Atomically do a bitwise and operation between OPERAND and *OBJP. | |
| #define | atomic_fetch_and_store(OBJP, DESIRED) |
| Store DESIRED into the object behind OBJP and return its previous value. | |
| #define | atomic_fetch_max(OBJP, OPERAND) |
| #define | atomic_fetch_or(OBJP, OPERAND) P00_FETCH_OP((OBJP), (OPERAND), __sync_fetch_and_or, |=) |
| Atomically do a bitwise or operation between OPERAND and *OBJP. | |
| #define | atomic_fetch_sub(OBJP, OPERAND) P00_FETCH_OP((OBJP), (OPERAND), __sync_fetch_and_sub, -=) |
| Atomically subtract OPERAND from *OBJP. | |
| #define | atomic_fetch_xor(OBJP, OPERAND) P00_FETCH_OP((OBJP), (OPERAND), __sync_fetch_and_xor, ^=) |
| Atomically do a bitwise xor operation between OPERAND and *OBJP. | |
| #define | atomic_init(OBJP, VAL) |
| Initialize the object behind OBJP with value VAL. | |
| #define | ATOMIC_INT128_LOCK_FREE 0 |
| #define | ATOMIC_INT16_LOCK_FREE 0 |
| #define | ATOMIC_INT32_LOCK_FREE 0 |
| #define | ATOMIC_INT64_LOCK_FREE 0 |
| #define | ATOMIC_INT8_LOCK_FREE 0 |
| #define | ATOMIC_INT_LOCK_FREE ATOMIC_INT8_LOCK_FREE |
| #define | ATOMIC_INTPTR_LOCK_FREE ATOMIC_INT8_LOCK_FREE |
| #define | atomic_is_lock_free(OBJP) (!offsetof(__typeof__(*OBJP), p00_xval)) |
| return true if OBJP points to a lock-free object | |
| #define | ATOMIC_LLONG_LOCK_FREE ATOMIC_INT8_LOCK_FREE |
| #define | atomic_load(OBJP) |
| Return the value of the object behind OBJP. | |
| #define | ATOMIC_LONG_LOCK_FREE ATOMIC_INT8_LOCK_FREE |
| #define | ATOMIC_POINTER_LOCK_FREE ATOMIC_INTPTR_LOCK_FREE |
| #define | ATOMIC_SHORT_LOCK_FREE ATOMIC_INT8_LOCK_FREE |
| #define | atomic_signal_fence atomic_thread_fence |
| #define | atomic_store(OBJP, DES) |
| Store DESIRED into the object behind OBJP. | |
| #define | ATOMIC_VAR_INIT(V) { .p00_xval = { .p00_t = (V), }, } |
| Initialize a variable of an atomic type. | |
| #define | ATOMIC_WCHAR_LOCK_FREE ATOMIC_INT8_LOCK_FREE |
| #define | P99_ATOMIC_INHERIT(T) |
| #define | P99_ATOMIC_LOCK_FREE_TYPES P00_ATOMIC_LOCK_FREE_TYPES6_ |
| A list of types that are supposed to have lock-free atomic operations. | |
| #define | P99_CRITICAL |
| Protect the following block or statement as a critical section of the program. | |
| #define | P99_DECLARE_ATOMIC(T, NAME) |
| declare an atomic type that will use lock operations to guarantee atomicity | |
| #define | P99_DECLARE_ATOMIC_LOCK_FREE(T, NAME) |
| declare an atomic type that will have lock-free operations | |
| #define | P99_LIFO_CLEAR(L) atomic_fetch_and_store(L, 0) |
| Atomically clear an atomic LIFO L and return a pointer to the start of the list that it previously contained. | |
| #define | P99_LIFO_POP(L) |
| Pop the top element from an atomic LIFO L. | |
| #define | P99_LIFO_PUSH(L, EL) |
| Push element EL into an atomic LIFO L. | |
| #define | P99_LIFO_TABULATE(TYPE, TAB, L) |
| #define | P99_LIFO_TOP(L) atomic_load(L) |
| Return a pointer to the top element of an atomic LIFO L. | |
| #define | P99_SPIN_EXCLUDE(FLAGP) |
| Protect the following block or statement as a critical section of the program by using FLAGP as a spinlock. | |
| #define | P99_UINT_DEFAULT(T) __typeof__(P99_GENERIC_SIZE_LIT(sizeof(T), (uintptr_t){ 0 }, P00_UINT_TYPE_LIST)) |
| A default unsigned integer type for type T. | |
Typedefs | |
| typedef struct atomic_bool | atomic_bool |
Atomic access to a value of type bool | |
| typedef struct atomic_double _Complex double _Complex | atomic_cdouble |
| typedef struct atomic_float _Complex float _Complex | atomic_cfloat |
| typedef struct atomic_char | atomic_char |
| typedef atomic_char16_t | atomic_char16_t |
| typedef atomic_char32_t | atomic_char32_t |
| typedef struct atomic_char_ptr | atomic_char_ptr |
| typedef struct atomic_long double _Complex long double _Complex | atomic_cldouble |
| typedef struct atomic_double double | atomic_double |
| typedef struct atomic_flag | atomic_flag |
| typedef struct atomic_float float | atomic_float |
| typedef struct atomic_int | atomic_int |
Atomic access to a value of type int | |
| typedef atomic_int_fast16_t | atomic_int_fast16_t |
| typedef atomic_int_fast32_t | atomic_int_fast32_t |
| typedef atomic_int_fast64_t | atomic_int_fast64_t |
| typedef atomic_int_fast8_t | atomic_int_fast8_t |
| typedef atomic_int_least16_t | atomic_int_least16_t |
| typedef atomic_int_least32_t | atomic_int_least32_t |
| typedef atomic_int_least64_t | atomic_int_least64_t |
| typedef atomic_int_least8_t | atomic_int_least8_t |
| typedef atomic_intmax_t | atomic_intmax_t |
| typedef atomic_intptr_t | atomic_intptr_t |
| typedef struct atomic_long double long double | atomic_ldouble |
| typedef struct atomic_llong | atomic_llong |
| typedef struct atomic_long | atomic_long |
| typedef atomic_ptrdiff_t | atomic_ptrdiff_t |
| typedef struct atomic_schar | atomic_schar |
| typedef struct atomic_schar_ptr | atomic_schar_ptr |
| typedef struct atomic_short | atomic_short |
| typedef atomic_size_t | atomic_size_t |
| typedef struct atomic_uchar | atomic_uchar |
| typedef struct atomic_uchar_ptr | atomic_uchar_ptr |
| typedef struct atomic_uint | atomic_uint |
| typedef atomic_uint_fast16_t | atomic_uint_fast16_t |
| typedef atomic_uint_fast32_t | atomic_uint_fast32_t |
| typedef atomic_uint_fast64_t | atomic_uint_fast64_t |
| typedef atomic_uint_fast8_t | atomic_uint_fast8_t |
| typedef atomic_uint_least16_t | atomic_uint_least16_t |
| typedef atomic_uint_least32_t | atomic_uint_least32_t |
| typedef atomic_uint_least64_t | atomic_uint_least64_t |
| typedef atomic_uint_least8_t | atomic_uint_least8_t |
| typedef atomic_uintmax_t | atomic_uintmax_t |
| typedef atomic_uintptr_t | atomic_uintptr_t |
| typedef struct atomic_ullong | atomic_ullong |
| typedef struct atomic_ulong | atomic_ulong |
| typedef struct atomic_ushort | atomic_ushort |
| typedef atomic_wchar_t | atomic_wchar_t |
| typedef enum memory_order | memory_order |
Enumeration type enum memory_order and typedef memory_order . | |
Enumerations | |
| enum | memory_order { memory_order_relaxed, memory_order_consume, memory_order_acquire, memory_order_release, memory_order_acq_rel, memory_order_seq_cst, memory_order_amount, memory_order_max = ((size_t)( memory_order_amount ) - 1u), memory_order_min = 0 } |
Functions | |
| void | atomic_thread_fence (memory_order p00_ord) |
| char const * | memory_order_getname (memory_order p00_x) |
| Get a string with the name of constant p00_x of type :: memory_order. | |
| memory_order | memory_order_parse (char const *p00_s) |
| Parse a string p00_s for the longest matching constant of type :: memory_order. | |
1.7.6.1
