P99
 All Data Structures Files Functions Variables Typedefs Enumerations Enumerator Friends Defines
p99_generic.h
Go to the documentation of this file.
00001 /* This may look like nonsense, but it really is -*- mode: C -*-             */
00002 /*        */
00003 /* Except of parts copied from previous work and as explicitly stated below, */
00004 /* the author and copyright holder for this work is                          */
00005 /* (C) copyright  2012 Jens Gustedt, INRIA, France                           */
00006 /*        */
00007 /* This file is free software; it is part of the P99 project.                */
00008 /* You can redistribute it and/or modify it under the terms of the QPL as    */
00009 /* given in the file LICENSE. It is distributed without any warranty;        */
00010 /* without even the implied warranty of merchantability or fitness for a     */
00011 /* particular purpose.                                                       */
00012 /*        */
00013 #ifndef     P99_GENERIC_H_
00014 # define    P99_GENERIC_H_
00015
00016 #include "p99_for.h"
00017
00022 #ifndef P00_DOXYGEN
00023
00024 #define P00_GENERIC_TYPE(T, EXP) T
00025 #define P00_GENERIC_SIZE_(UI, EXP) char(*)[UI]
00026 #define P00_GENERIC_EXP_(T, EXP) (EXP)
00027 #define P00_GENERIC_LIT_(T, EXP) (EXP){ 0 }
00028
00029 #define P00_GENERIC_SIZE_LIT(EXP, PAIR, I) P00_GENERIC_EXPRESSION(P00_GENERIC_SIZE_, P00_GENERIC_LIT_, EXP, PAIR, I)
00030 #define P00_GENERIC_SIZE(EXP, PAIR, I) P00_GENERIC_EXPRESSION(P00_GENERIC_SIZE_, P00_GENERIC_EXP_, EXP, PAIR, I)
00031 #define P00_GENERIC_EXP(EXP, PAIR, I) P00_GENERIC_EXPRESSION(P00_GENERIC_TYPE, P00_GENERIC_EXP_, EXP, PAIR, I)
00032 #define P00_GENERIC_LIT(EXP, PAIR, I) P00_GENERIC_EXPRESSION(P00_GENERIC_TYPE, P00_GENERIC_LIT_, EXP, PAIR, I)
00033
00034 #if p99_has_extension(c_generic_selections)
00035
00036 #define P00_GENERIC_EXPRESSION(TOP, EOP, EXP, PAIR, I)         \
00037 TOP PAIR: EOP PAIR
00038
00039 #define P00_GENERIC_(N, MOP, EXP, DEF, ...)                    \
00040 p99_extension                                                  \
00041 _Generic                                                       \
00042 ((EXP),                                                        \
00043  P99_IF_EMPTY(DEF)()(default: (DEF),)                          \
00044  P99_FOR((EXP), N, P00_SEQ, MOP, __VA_ARGS__)                  \
00045  )
00046
00047 #elif defined(__GNUC__)
00048
00049 #define P00_GENERIC_CLOSE(A,B,C) )
00050
00051 #define P00_GENERIC_EXPRESSION(TOP, EOP, EXP, PAIR, I)         \
00052 __builtin_choose_expr                                          \
00053 (__builtin_types_compatible_p(__typeof__ EXP, TOP PAIR),       \
00054  EOP PAIR
00055
00056 /* If no default is given, the idea of _Generic is to abort
00057    compilation. To emulate this behavior we would have to produce an
00058    expression that is valid as such, but can't be used in any valid
00059    context. Such an expression doesn't exist, I think, since any valid
00060    expression can always be used in a void context.
00061
00062    The idea for that case is to use an extern function that never will
00063    be defined and that bears a special attribute that inhibits this
00064    function to be called.  This function is then called through a
00065    sizeof expression for VLA with side effect, such that it only
00066    triggers when that particular branch is taken. */
00067
00068 __attribute__((__error__("Invalid choice in type generic expression")))
00069 extern size_t p00_invalid_type_in_generic(char const*);
00070
00071 #define P00_INVALID_TYPE_IN_GENERIC(EXP, STR)                  \
00072 p00_invalid_type_in_generic(__FILE__                           \
00073                             P99_STRINGIFY(:__LINE__)           \
00074                             ": invalid type generic choice `"  \
00075                             P99_STRINGIFY(EXP)                 \
00076                             "` for "                           \
00077                             STR)
00078
00079 #define P00_GENERIC_(N, MOP, EXP, DEF, ...)                                \
00080   P99_FOR((EXP), N, P00_SEQ, MOP, __VA_ARGS__),                            \
00081     P99_IF_EMPTY(DEF)(P00_INVALID_TYPE_IN_GENERIC(EXP, #__VA_ARGS__))(DEF) \
00082     P99_FOR(, N, P00_SER, P00_GENERIC_CLOSE, P99_DUPL(N, ))
00083
00084 #endif
00085
00086 #define P00_GENERIC0(MOP, EXP, DEF, ...)                       \
00087 P00_GENERIC_                                                   \
00088 (                                                              \
00089  P99_NARG(__VA_ARGS__),                                        \
00090  P00_ROBUST(MOP),                                              \
00091  P00_ROBUST(EXP),                                              \
00092  P00_ROBUST(DEF),                                              \
00093  __VA_ARGS__)
00094
00095 #define P00_GENERIC(N, ...) P99_IF_LT(N, 3)()(P00_GENERIC0(__VA_ARGS__))
00096
00097 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_GENERIC, 0)
00098 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_GENERIC, 2)
00099 #define P99_GENERIC(...) P00_GENERIC(P99_NARG(__VA_ARGS__), P00_GENERIC_EXP, __VA_ARGS__)
00100
00101 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_GENERIC_LIT, 0)
00102 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_GENERIC_LIT, 2)
00103 #define P99_GENERIC_LIT(...) P00_GENERIC(P99_NARG(__VA_ARGS__), P00_GENERIC_LIT, __VA_ARGS__)
00104
00105 #define P00_GENERIC_SIZE0(...) P00_GENERIC(P99_NARG(__VA_ARGS__), P00_GENERIC_SIZE, __VA_ARGS__)
00106
00107 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_GENERIC_SIZE, 0)
00108 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_GENERIC_SIZE, 2)
00109 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_GENERIC_SIZE, 3)
00110 #define P99_GENERIC_SIZE(UI, ...) P00_GENERIC_SIZE0((char(*)[(size_t)(UI)]){ 0 }, __VA_ARGS__)
00111
00112 #define P00_GENERIC_SIZE_LIT0(...) P00_GENERIC(P99_NARG(__VA_ARGS__), P00_GENERIC_SIZE_LIT, __VA_ARGS__)
00113
00114 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_GENERIC_SIZE_LIT, 0)
00115 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_GENERIC_SIZE_LIT, 2)
00116 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_GENERIC_SIZE_LIT, 3)
00117 #define P99_GENERIC_SIZE_LIT(UI, ...) P00_GENERIC_SIZE_LIT0((char(*)[(size_t)(UI)]){ 0 }, __VA_ARGS__)
00118
00119
00120 #if p99_has_extension(c_generic_selections)
00121
00122 # define P99_TYPED_TERN(COND, YES, NO)                         \
00123 (P99_GENERIC                                                   \
00124  ((char(*)[1 + !!(COND)]){ 0 },                                \
00125   (NO),                                                        \
00126   (char(*)[2], (YES))))
00127
00128 #elif defined(__GNUC__)
00129
00130 # define P99_TYPED_TERN __builtin_choose_expr
00131
00132 #else
00133
00134 #define P99_TYPED_TERN(COND, YES, NO) only_implemented_with_C11_or_gcc
00135
00136
00137 #endif
00138
00139
00140 #define P00_TYPE_CHOICE(YES, T, I) (T, YES)
00141
00142 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_TYPE_CHOICE, 0)
00143 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_TYPE_CHOICE, 1)
00144 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_TYPE_CHOICE, 2)
00145 #define P99_TYPE_CHOICE(EXP, YES, NO, ...)                                   \
00146 P99_GENERIC        \
00147 ((EXP),        \
00148  NO,        \
00149  P99_FOR(YES, P99_NARG(__VA_ARGS__), P00_SEQ, P00_TYPE_CHOICE, __VA_ARGS__))
00150
00151 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_TYPE_UNSIGNED, 0)
00152 #define P99_TYPE_UNSIGNED(EXP)      P99_TYPE_CHOICE((EXP), 1, 0, P99_STD_UNSIGNED_TYPES)
00153 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_TYPE_SIGNED, 0)
00154 #define P99_TYPE_SIGNED(EXP)        P99_TYPE_CHOICE((EXP), 1, 0, P99_STD_SIGNED_TYPES)
00155 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_TYPE_REAL_FLOATING, 0)
00156 #define P99_TYPE_REAL_FLOATING(EXP) P99_TYPE_CHOICE((EXP), 1, 0, P99_STD_REAL_FLOATING_TYPES)
00157 #ifndef __STDC_NO_COMPLEX__
00158 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_TYPE_COMPLEX, 0)
00159 # define P99_TYPE_COMPLEX(EXP)       P99_TYPE_CHOICE((EXP), 1, 0, P99_STD_COMPLEX_TYPES)
00160 #endif
00161 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_TYPE_FLOATING, 0)
00162 #define P99_TYPE_FLOATING(EXP)      P99_TYPE_CHOICE((EXP), 1, 0, P99_STD_FLOATING_TYPES)
00163 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_TYPE_BASIC, 0)
00164 #define P99_TYPE_BASIC(EXP)         P99_TYPE_CHOICE((EXP), 1, 0, P99_STD_BASIC_TYPES)
00165 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_TYPE_CHARACTER, 0)
00166 #define P99_TYPE_CHARACTER(EXP)     P99_TYPE_CHOICE((EXP), 1, 0, P99_STD_CHARACTER_TYPES)
00167 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_TYPE_INTEGER, 0)
00168 #define P99_TYPE_INTEGER(EXP)       P99_TYPE_CHOICE((EXP), 1, 0, P99_STD_INTEGER_TYPES)
00169 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_TYPE_REAL, 0)
00170 #define P99_TYPE_REAL(EXP)          P99_TYPE_CHOICE((EXP), 1, 0, P99_STD_REAL_TYPES)
00171 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_TYPE_ARITHMETIC, 0)
00172 #define P99_TYPE_ARITHMETIC(EXP)    P99_TYPE_CHOICE((EXP), 1, 0, P99_STD_ARITHMETIC_TYPES)
00173
00174 #define P00_SIZE_CHOICE(YES, UI, I) (char(*)[(size_t)(UI)], YES)
00175
00176 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_SIZE_CHOICE, 0)
00177 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_SIZE_CHOICE, 1)
00178 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_SIZE_CHOICE, 2)
00179 #define P99_SIZE_CHOICE(UI, YES, NO, ...)                                    \
00180 P99_GENERIC        \
00181  ((char(*)[(size_t)(UI)])0,                                                  \
00182  NO,        \
00183  P99_FOR(YES, P99_NARG(__VA_ARGS__), P00_SEQ, P00_SIZE_CHOICE, __VA_ARGS__))
00184
00185
00186 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_SIZE_INDICATOR, 0)
00187 #define P99_SIZE_INDICATOR(UI, ...) P99_SIZE_CHOICE(UI, 1, 0, __VA_ARGS__)
00188
00189
00190 #define P00_DECLARE_INLINE_EXPRESSION1(EXT, BASE, EXP, A)      \
00191 p99_inline                                                     \
00192 P99_BUILTIN_TYPE(EXT) P99_PASTE3(p00_gen_, BASE, EXT)          \
00193 (P99_BUILTIN_TYPE(EXT) A)                                      \
00194 {                                                              \
00195   return (EXP);                                                \
00196 }
00197
00198 #define P00_DECLARE_INLINE_EXPRESSION2(EXT, BASE, EXP, A, B)   \
00199 p99_inline                                                     \
00200 P99_BUILTIN_TYPE(EXT) P99_PASTE3(p00_gen_, BASE, EXT)          \
00201 (P99_BUILTIN_TYPE(EXT) A, P99_BUILTIN_TYPE(EXT) B)             \
00202 {                                                              \
00203   return (EXP);                                                \
00204 }
00205
00206 #define P00_DECLARE_INLINE_EXPRESSION3(EXT, BASE, EXP, A, B, C) \
00207 p99_inline                                                      \
00208 P99_BUILTIN_TYPE(EXT) P99_PASTE3(p00_gen_, BASE, EXT)           \
00209 (P99_BUILTIN_TYPE(EXT) A, P99_BUILTIN_TYPE(EXT) B,              \
00210  P99_BUILTIN_TYPE(EXT) C)                                       \
00211 {                                                               \
00212   return (EXP);                                                 \
00213 }
00214
00215 #define P00_DECLARE_INLINE_EXPRESSION4(EXT, BASE, EXP, A, B, C, D) \
00216 p99_inline                                                         \
00217 P99_BUILTIN_TYPE(EXT) P99_PASTE3(p00_gen_, BASE, EXT)              \
00218 (P99_BUILTIN_TYPE(EXT) A, P99_BUILTIN_TYPE(EXT) B,                 \
00219  P99_BUILTIN_TYPE(EXT) C, P99_BUILTIN_TYPE(EXT) D)                 \
00220 {        \
00221   return (EXP);                                                    \
00222 }
00223
00224 #define P00_DECLARE_INLINE_EXPRESSION5(EXT, BASE, EXP, A, B, C, D, E) \
00225 p99_inline                                                            \
00226 P99_BUILTIN_TYPE(EXT) P99_PASTE3(p00_gen_, BASE, EXT)                 \
00227 (P99_BUILTIN_TYPE(EXT) A, P99_BUILTIN_TYPE(EXT) B,                    \
00228  P99_BUILTIN_TYPE(EXT) C, P99_BUILTIN_TYPE(EXT) D,                    \
00229  P99_BUILTIN_TYPE(EXT) E)                                             \
00230 {        \
00231   return (EXP);                                                       \
00232 }
00233
00234 #define P00_DECLARE_INLINE_EXPRESSION6(EXT, BASE, EXP, A, B, C, D, E, F) \
00235 p99_inline                                                               \
00236 P99_BUILTIN_TYPE(EXT) P99_PASTE3(p00_gen_, BASE, EXT)                    \
00237 (P99_BUILTIN_TYPE(EXT) A, P99_BUILTIN_TYPE(EXT) B,                       \
00238  P99_BUILTIN_TYPE(EXT) C, P99_BUILTIN_TYPE(EXT) D,                       \
00239  P99_BUILTIN_TYPE(EXT) E, P99_BUILTIN_TYPE(EXT) F)                       \
00240 {        \
00241   return (EXP);                                                          \
00242 }
00243
00244 P00_DOCUMENT_IDENTIFIER_ARGUMENT(P99_DECLARE_INLINE_EXPRESSION, 0)
00245 P00_DOCUMENT_IDENTIFIER_ARGUMENT(P99_DECLARE_INLINE_EXPRESSION, 1)
00246 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_DECLARE_INLINE_EXPRESSION, 2)
00247 #define P99_DECLARE_INLINE_EXPRESSION(...)                                                  \
00248 P99_PASTE2(P00_DECLARE_INLINE_EXPRESSION, P99_MINUS(P99_NARG(__VA_ARGS__), 3))(__VA_ARGS__)
00249
00250 #define P00_DECLARE_INLINE_EXPRESSION_(...) P99_DECLARE_INLINE_EXPRESSION(__VA_ARGS__)
00251 #define P00_DECLARE_INLINE_EXPRESSION(ARGS, EXT, I) P00_DECLARE_INLINE_EXPRESSION_(EXT, P00_ROBUST ARGS)
00252
00253 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_DECLARE_INLINE_EXPRESSIONS, 0)
00254 #define P99_DECLARE_INLINE_EXPRESSIONS(NEPL, ...)                                         \
00255 P99_FOR(NEPL, P99_NARG(__VA_ARGS__), P00_SER, P00_DECLARE_INLINE_EXPRESSION, __VA_ARGS__) \
00256 P99_MACRO_END(P99_DECLARE_INLINE_EXPRESSIONS, __VA_ARGS__)
00257
00258 extern void p00_invalid_function(void*, ...);
00259
00260 #define P00_GEN_EXPR(BASE, EXT, I) (P99_BUILTIN_TYPE(EXT), P99_PASTE3(p00_gen_, BASE, EXT))
00261
00262 P00_DOCUMENT_IDENTIFIER_ARGUMENT(P99_GEN_EXPR, 0)
00263 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_GEN_EXPR, 1)
00264 #define P99_GEN_EXPR(BASE, EXPR, ...)                                                 \
00265 P99_GENERIC(EXPR,        \
00266             p00_invalid_function,                                                     \
00267             P99_FOR(BASE, P99_NARG(__VA_ARGS__), P00_SEQ, P00_GEN_EXPR, __VA_ARGS__))
00268
00269
00270
00271
00272 P99_DECLARE_INLINE_EXPRESSIONS((maximum,
00273                                 (p00_a >= p00_b) ? p00_a : p00_b,
00274                                 p00_a, p00_b),
00275                                P99_STD_REAL_EXTS
00276                               );
00277
00278 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_GEN_MAX, 0)
00279 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_GEN_MAX, 1)
00280 #define P99_GEN_MAX(A, B)                                      \
00281 P99_GEN_EXPR(maximum, ((A) >= (B)) ? (A) : (B),                \
00282              P99_STD_REAL_EXTS                                 \
00283              )                                                 \
00284 ((A), (B))
00285
00286 P99_DECLARE_INLINE_EXPRESSIONS((minimum,
00287                                 (p00_a <= p00_b) ? p00_a : p00_b,
00288                                 p00_a, p00_b),
00289                                P99_STD_REAL_EXTS
00290                               );
00291
00292 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_GEN_MIN, 0)
00293 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_GEN_MIN, 1)
00294 #define P99_GEN_MIN(A, B)                                      \
00295 P99_GEN_EXPR(minimum, ((A) <= (B)) ? (A) : (B),                \
00296              P99_STD_REAL_EXTS                                 \
00297              )                                                 \
00298 ((A), (B))
00299
00300
00301 P99_DECLARE_INLINE_EXPRESSIONS((abs,
00302                                 (p00_a >= 0) ? p00_a : -p00_a,
00303                                 p00_a),
00304                                P99_STD_REAL_EXTS
00305                               );
00306
00307 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_GEN_ABS, 0)
00308 #define P99_GEN_ABS(A) P99_GEN_EXPR(abs, ((A) >= 0) ? (A) : -(A), P99_STD_REAL_EXTS)(A)
00309
00310 #define p00_gen_sind sin
00311 #define p00_gen_sinf sinf
00312 #define p00_gen_sinld sinl
00313 #define p00_gen_sindc csin
00314 #define p00_gen_sinfc csinf
00315 #define p00_gen_sinldc csinl
00316
00317 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_GEN_SIN, 0)
00318 #define P99_GEN_SIN(A) P99_GEN_EXPR(sin, (A), P99_STD_FLOATING_EXTS)(A)
00319
00320 inline int* p00_generic_test(int * p00_a) {
00321   double *p00_x;
00322   switch (P99_GEN_ABS(*p00_a % 3)) {
00323   case 0:
00324     return P99_GENERIC(&*p00_a,
00325                        /* empty default expression */,
00326                        (int*, p00_a),
00327                        (double*, p00_x+1),
00328                        (float*, p00_x+2));
00329   case 1:
00330     return P99_GENERIC(&*p00_a,
00331                        /* another form of empty default */,
00332                        (double[7], P99_GEN_SIN(((p00_x+0)))),
00333                        (int*, p00_a),
00334                        (float*, p00_x+2));
00335   default:
00336     return P99_GENERIC(&*p00_a,
00337                        /* default expression: */ p00_x,
00338                        (double*, p00_x+0),
00339                        (float[7], p00_x+1),
00340                        (int*, p00_a));
00341   }
00342 }
00343
00344 #else
00345
00442 #define P99_GENERIC(...)
00443
00463 #define P99_GENERIC_LIT(...)
00464
00496 #define P99_GENERIC_SIZE(UI, ...)
00497
00506 #define P99_GENERIC_SIZE_LIT(UI, ...)
00507
00517 #define P99_TYPED_TERN(COND, YES, NO)
00518
00525 #define P00_TYPE_CHOICE(YES, T, I) (T, YES)
00526
00534 #define P99_TYPE_CHOICE(EXP, YES, NO, ...)
00535
00542 #define P99_TYPE_UNSIGNED(EXP)      P99_TYPE_CHOICE((EXP), 1, 0, P99_STD_UNSIGNED_TYPES)
00543 #define P99_TYPE_SIGNED(EXP)        P99_TYPE_CHOICE((EXP), 1, 0, P99_STD_SIGNED_TYPES)
00544 #define P99_TYPE_REAL_FLOATING(EXP) P99_TYPE_CHOICE((EXP), 1, 0, P99_STD_REAL_FLOATING_TYPES)
00545 # define P99_TYPE_COMPLEX(EXP)       P99_TYPE_CHOICE((EXP), 1, 0, P99_STD_COMPLEX_TYPES)
00546 #define P99_TYPE_FLOATING(EXP)      P99_TYPE_CHOICE((EXP), 1, 0, P99_STD_FLOATING_TYPES)
00547 #define P99_TYPE_BASIC(EXP)         P99_TYPE_CHOICE((EXP), 1, 0, P99_STD_BASIC_TYPES)
00548 #define P99_TYPE_CHARACTER(EXP)     P99_TYPE_CHOICE((EXP), 1, 0, P99_STD_CHARACTER_TYPES)
00549 #define P99_TYPE_INTEGER(EXP)       P99_TYPE_CHOICE((EXP), 1, 0, P99_STD_INTEGER_TYPES)
00550 #define P99_TYPE_REAL(EXP)          P99_TYPE_CHOICE((EXP), 1, 0, P99_STD_REAL_TYPES)
00551 #define P99_TYPE_ARITHMETIC(EXP)    P99_TYPE_CHOICE((EXP), 1, 0, P99_STD_ARITHMETIC_TYPES)
00552
00570 #define P99_SIZE_CHOICE(UI, YES, NO, ...)
00571
00591 #define P99_SIZE_INDICATOR(UI, ...)
00592
00629 #define P99_DECLARE_INLINE_EXPRESSION(EXT, BASE, EXP, ...)
00630
00664 #define P99_DECLARE_INLINE_EXPRESSIONS(NEPL, ...)
00665
00666 extern void p00_invalid_function(void*, ...);
00667
00738 #define P99_GEN_EXPR(BASE, EXPR, ...)
00739
00740 #define P99_GEN_MAX(A, B)                                      \
00741 P99_GEN_EXPR(maximum, ((A) >= (B)) ? (A) : (B),                \
00742              P99_STD_REAL_EXTS                                 \
00743              )                                                 \
00744 ((A), (B))
00745
00746 #define P99_GEN_MIN(A, B)                                      \
00747 P99_GEN_EXPR(minimum, ((A) <= (B)) ? (A) : (B),                \
00748              P99_STD_REAL_EXTS                                 \
00749              )                                                 \
00750 ((A), (B))
00751
00752
00753 #define P99_GEN_ABS(A) P99_GEN_EXPR(abs, ((A) >= 0) ? (A) : -(A), P99_STD_REAL_EXTS)(A)
00754
00761 #define P99_GEN_SIN(A) P99_GEN_EXPR(sin, (A), P99_STD_FLOATING_EXTS)(A)
00762
00767 #endif
00768
00769
00770 #endif
