P99
Modules | Defines | Functions
C11 atomic operations
Emulating features of C11
+ Collaboration diagram for C11 atomic operations:
Modules
 Stub replacements of C11 atomic operations
 Atomic_macros
 Atomic_enum
 Atomic_types
 Memory Fences
Defines
#define atomic_compare_exchange_weak(OBJP, EXPECTED, DESIRED)
 Atomically compare *OBJP to *EXPECTED and set it to DESIRED if they are equal.
#define atomic_exchange(OBJP, DESIRED)
 Store DESIRED into the object behind OBJP and return its previous value.
#define atomic_fetch_add(OBJP, OPERAND)   P00_FETCH_OP((OBJP), (OPERAND), __sync_fetch_and_add, +=)
 Atomically add OPERAND to *OBJP.
#define atomic_fetch_add_conditional(OBJP, OPERAND)
#define atomic_fetch_and(OBJP, OPERAND)   P00_FETCH_OP((OBJP), (OPERAND), __sync_fetch_and_and, &=)
 Atomically do a bitwise AND operation between OPERAND and *OBJP.
#define atomic_fetch_max(OBJP, OPERAND)
#define atomic_fetch_or(OBJP, OPERAND)   P00_FETCH_OP((OBJP), (OPERAND), __sync_fetch_and_or, |=)
 Atomically do a bitwise OR operation between OPERAND and *OBJP.
#define atomic_fetch_sub(OBJP, OPERAND)   P00_FETCH_OP((OBJP), (OPERAND), __sync_fetch_and_sub, -=)
 Atomically subtract OPERAND from *OBJP.
#define atomic_fetch_xor(OBJP, OPERAND)   P00_FETCH_OP((OBJP), (OPERAND), __sync_fetch_and_xor, ^=)
 Atomically do a bitwise XOR operation between OPERAND and *OBJP.
#define atomic_init(OBJP, VAL)
 Initialize the object behind OBJP with value VAL.
#define atomic_is_lock_free(OBJP)   (!offsetof(__typeof__(*OBJP), p00_xval))
 return true if OBJP points to a lock-free object
#define atomic_load(OBJP)
 Return the value of the object behind OBJP.
#define atomic_store(OBJP, DES)
 Store DESIRED into the object behind OBJP.
#define P99_CRITICAL
 Protect the following block or statement as a critical section of the program.
#define P99_FIFO(T)   P99_PASTE2(p00_fifo_, T)
#define P99_FIFO_APPEND(L, EL)
 Append element EL to an atomic FIFO L.
#define P99_FIFO_CLEAR(L)
 Atomically clear an atomic FIFO L and return a pointer to the start of the list that it previously contained.
#define P99_FIFO_DECLARE(T)
#define P99_FIFO_INITIALIZER(HEAD, TAIL)
#define P99_FIFO_POP(L)
 Pop the front element from an atomic FIFO L.
#define P99_FIFO_TABULATE(TYPE, TAB, L)
#define P99_LIFO(T)   _Atomic(P99_PASTE2(p00_lifo_, T))
#define P99_LIFO_CLEAR(L)   atomic_exchange(L, 0)
 Atomically clear an atomic LIFO L and return a pointer to the start of the list that it previously contained.
#define P99_LIFO_DECLARE(T)
#define P99_LIFO_INITIALIZER(VAL)   ATOMIC_VAR_INIT((void*)VAL)
#define P99_LIFO_POP(L)
 Pop the top element from an atomic LIFO L.
#define P99_LIFO_PUSH(L, EL)
 Push element EL into an atomic LIFO L.
#define P99_LIFO_TABULATE(TYPE, TAB, L)
#define P99_LIFO_TOP(L)   atomic_load(L)
 Return a pointer to the top element of an atomic LIFO L.
#define P99_SPIN_EXCLUDE(FLAGP)
 Protect the following block or statement as a critical section of the program by using FLAGP as a spinlock.
Functions
void atomic_flag_clear (volatile atomic_flag *p00_objp)
 Unconditionally set *p00_objp to false.
void atomic_flag_clear_explicit (volatile atomic_flag *p00_objp, memory_order p00_ord)
void atomic_flag_lock (volatile atomic_flag *p00_objp)
 extension: spin on p00_objp setting the flag until the state before was "clear"
_Bool atomic_flag_test_and_set (volatile atomic_flag *p00_objp)
 Unconditionally set *object to true and return the previous value.
_Bool atomic_flag_test_and_set_explicit (volatile atomic_flag *p00_objp, memory_order p00_ord)
_Bool atomic_flag_trylock (volatile atomic_flag *p00_objp)
 extension: set the flag and return true if we are the first to do so
void atomic_flag_unlock (volatile atomic_flag *p00_objp)
 extension: clear the flag unconditionally
Detailed Description
This is a stub implementation of C11 atomic types and operations.
This uses gcc extensions
We also use __sync_lock_test_and_set and other similar built-ins if they are available. If not, __sync_lock_test_and_set and __sync_lock_release are implemented in assembler (for 4 byte integers) and all other operations are synthesized with an atomic_flag that is used as a spinlock.
See also:
_Atomic
P99_DECLARE_ATOMIC
 All Data Structures Files Functions Variables Typedefs Enumerations Enumerator Friends Defines
