P99
Value:
p99_extension \
P99_MACRO_PVAR(p00_objp, (OBJP)); \
P99_MACRO_VAR(p00_op, (OPERAND)); \
P99_MACRO_VAR(p00_ret, atomic_load(p00_objp)); \
while (p00_ret <= p00_op) { \
if (atomic_compare_exchange_weak(p00_objp, &p00_ret, p00_op)) break; \
/* be sure that the result can not be used as an lvalue */ \
register __typeof__(p00_ret = p00_ret) p00_r = p00_ret; \
p00_r; \
Definition at line 1325 of file p99_atomic.h. |
1.7.6.1
