P99
#define P99_IF_COMPILER (   COMP,
)    P00_COMPILER_PRAGMA_ ## COMP(P99_STRINGIFY(__VA_ARGS__))
Issue the pragma that is given as a supplementary argument iff the actual compiler is COMP.
See also:
P99_COMPILER
Definition at line 1052 of file p99_compiler.h.
 All Data Structures Files Functions Variables Typedefs Enumerations Enumerator Friends Defines
