P99
Macros
Default arguments and types for functions
As a C++ like feature, this series of macros can be used to provide default arguments to functions and also to improve type safety for variadic functions. More...
+ Collaboration diagram for Default arguments and types for functions:
Macros
#define P99_CALL_DEFARG(NAME, M, ...)   NAME(__VA_ARGS__)
 Define a replacement macro for functions that can provide default arguments to the underlying real function. More...
#define P99_CALL_DEFARG_LIST(NAME, M, ...)   __VA_ARGS__
 Expand an argument list with default arguments. More...
#define P99_CALL_VA_ARG(NAME, M, T, ...)   NAME(__VA_ARGS__)
 Assure type safety for variadic functions. More...
#define P99_DECLARE_DEFARG(NAME, ...)
 Provide default arguments for macro NAME. More...
#define P99_DEFARG_DOCU(NAME)
 Provide a documentation section to a function defined with P99_CALL_DEFARG. More...
#define P99_DEFINE_DEFARG(NAME, ...)
 Define the symbols that are declared through a corresponding call P99_DECLARE_DEFARG. More...
#define P99_INSTANTIATE(RT, NAME, ...)   RT NAME(__VA_ARGS__)
 Instantiate an inline function. More...
#define P99_PROTOTYPE(...)
 Define the prototype of function NAME. More...
Detailed Description
This goes in several parts.
Another feature that is provided here is a macro that allows you to prescribe a certain type to the arguments of a variadic function. In plain C these are dangerous, since C cannot guess the type that the implementation of the function expects. P99_CALL_VA_ARG may be used to overcome this problem.
