P99
Collaboration diagram for Generic type expressions:Modules | |
| Generic identification of families of types or values | |
Defines | |
| #define | P99_DECLARE_INLINE_EXPRESSION(EXT, BASE, EXP,...) |
| Declare an inline function of basename BASE for expression EXP, applied to the builtin type EXT. | |
| #define | P99_DECLARE_INLINE_EXPRESSIONS(NEPL,...) |
Declare a whole bunch of inline functions of basename BASE for expression EXP, applied to the builtin types as given in the argument list. | |
| #define | P99_GEN_ABS(A) P99_GEN_EXPR(abs, ((A) >= 0) ? (A) : -(A), P99_STD_REAL_EXTS)(A) |
| #define | P99_GEN_EXPR(BASE, EXPR,...) |
Produce a type generic expression that can be used as if it were an inline function. | |
| #define | P99_GEN_MAX(A, B) |
| #define | P99_GEN_MIN(A, B) |
| #define | P99_GEN_SIN(A) P99_GEN_EXPR(sin, (A), P99_STD_FLOATING_EXTS)(A) |
| Type generic macro to compute the sine of A. | |
| #define | P99_GENERIC(...) |
Type generic expression in anticipation of C11 _Generic. | |
| #define | P99_GENERIC_LIT(...) |
| For each generic choice return a compound literal of the chosen type. | |
| #define | P99_GENERIC_SIZE(UI,...) |
| Similar to P99_GENERIC but the choice is not according to the type of the expression UI but to its unsigned value. | |
| #define | P99_GENERIC_SIZE_LIT(UI,...) |
| Similar to P99_GENERIC_SIZE but returns a compound literal of the chosen type. | |
| #define | P99_TYPED_TERN(COND, YES, NO) |
A compile time ternary operator that is analogous to COND ? YES : NO that keeps the type of the chosen expression. | |
C11 provides a new feature to write template-like expressions with the macro preprocessor, _Generic. Here we provide some tools that emulate this feature by means of gcc specific extensions.
1.7.6.1
