P99
Preprocessor macros that perform simple arithmetic on decimal arguments. More...
Collaboration diagram for Preprocessor arithmetic operations:Defines | |
| #define | P99_ADD(_0, _1) |
| add two decimal numbers | |
| #define | P99_CDIM(NAME,...) P00_CDIM(P99_NARG(__VA_ARGS__), NAME, __VA_ARGS__) |
| Compute an absolute index in a multidimensional array in the same way as C. | |
| #define | P99_DIV(A, B) P99_CHS(A, P99_FOR(B, 32, P00_SEQ, P00_IDI, P00_ALL_ONES())) |
| Generate the quotient of non-negative decimal numbers A and B at preprocessing time. | |
| #define | P99_EVAL(EDEC) P99_PASTE2(P00_dec_eval_, EDEC) |
| evaluate the result of one of the arithmetic preprocessor | |
| #define | P99_MINUS(_0, _1) P00_MINUS(_0, _1, P99_IS_EQ(_0, _1), P99_IS_EQ_0(_0), P99_IS_EQ_0(_1)) |
| substract two decimal numbers | |
| #define | P99_MOD(A, B) P00_MOD(A, P99_DUPL(32, P99_SELS(B, P00_ASCENDING()))) |
| Generate the modulus of non-negative decimal numbers A and B at preprocessing time. | |
| #define | P99_MUL(A, B) P99_PASTE3(P00_MUL_, P99_IS_EQ_0(A), P99_IS_EQ_0(B))(A, B) |
| Generate the product of non-negative decimal numbers A and B at preprocessing time. | |
| #define | P99_PRED(N) P00_PRED(N) |
| Macro that expands to the predecessor of decimal constant N. | |
These are only implemented for small numbers, currently the limit is somewhere around P99_MAX_NUMBER
1.7.6.1
