P99
Apply the macro MACRO N times. The macro is called with the numbers In the following example we define an adhoc macro that initializes an array element with a certain structure type. The array typedef struct pair pair; struct pair { size_t index; double* aPos; }; #define ASIZE 10 double A[] = { P99_DUPL(ASIZE, 1.7) }; #define INIT_PAIR(I) [I] = { \ .index = I, \ .aPos = &A[I], \ } pair P[] = { P99_REPEAT(INIT_PAIR, ASIZE) };
1.7.6.1
