P99
#define P99_ACOPY (   TYPE,
  N,
  VAR,
Expand to an array literal of type TYPE[N] copying from another array.
The third argument is the array VAR to be copied from. The optional forth argument M is the number of elements from VAR that are to be copied. It defaults to N if omitted. Obviously we must always have M <= N for this to work.
This can be used to call a function with a copy of of VAR.
Remarks:
The base type of VAR must be assignment compatible with type TYPE.
Definition at line 314 of file p99_map.h.
 All Data Structures Files Functions Variables Typedefs Enumerations Enumerator Friends Defines
