P99
#define P99_IS_MIN (   FIRST,
)    P99_FOR(>= (FIRST), P99_NARG(__VA_ARGS__), P00_AND, P00_ISIT, __VA_ARGS__)
Check if argument FIRST is less than the other elements in the list.
Use this as follows:
 if (P99_IS_MIN(a, b, c, d, e, f)) {
   // a is smallest, do something special
 } else {
   // handle the base case
Warning:
argument 0 may be evaluated multiple times
Definition at line 381 of file p99_for.h.
 All Data Structures Files Functions Variables Typedefs Enumerations Enumerator Friends Defines
