C11 thread function return values.
- Enumerator:
| thrd_timedout |
returned by a timed wait function to indicate that the time specified in the call was reached without acquiring the requested resource
| thrd_success |
returned by a function to indicate that the requested operation succeeded
| thrd_busy |
returned by a function to indicate that the requested operation failed because a resource requested by a test and return function is already in use
| thrd_error |
| thrd_nomem |
returned by a function to indicate that the requested operation failed because it was unable to allocate memory
| thrd_intr |
(extension) returned by ::thrd_sleep to indicate that the corresponding request has been interrupted by a signal
Definition at line 112 of file p99_tss.h.
