P99
Collaboration diagram for C11 thread emulation on top of POSIX threads:Data Structures | |
| struct | p99_tss |
| A stub structure to hold a thread local variable if thread_local is not available. More... | |
Modules | |
| Thread_macros | |
| Thread_types | |
| Thread_enum | |
Defines | |
| #define | p99_call_once(FLAG, FUNC, ARG) |
| Call a function FUNC exactly once, optionally providing it with argument ARG. | |
| #define | P99_DECLARE_ONCE_CHAIN(T) extern p99_once_flag P99_PASTE3(p99_, T, _once) |
| Declare the symbols that are needed for the macro P99_INIT_CHAIN(). | |
| #define | P99_DECLARE_THREAD_LOCAL P99_TSS_DECLARE_LOCAL |
| declare a thread local variable NAME of type T | |
| #define | P99_DEFINE_ONCE_CHAIN(T,...) |
Define a function that will be called exactly once by P99_INIT_CHAIN(T). | |
| #define | P99_INIT_CHAIN(T) p99_call_once(&P99_PASTE3(p99_, T, _once), P99_PASTE3(p99_, T, _once).p00_init) |
| Ensure that the function that was defined with P99_DEFINE_ONCE_CHAIN has been called exactly once before proceeding. | |
| #define | P99_MUTUAL_EXCLUDE(MUT) |
Protect the following block or statement with mtx_t MUT. | |
| #define | P99_THREAD_LOCAL P99_TSS_LOCAL |
| an lvalue expression that returns the thread local instance of variable NAME | |
| #define | P99_TSS_DECLARE_LOCAL(T, NAME, DTOR) |
| declare a thread local variable NAME of type T and with destructor DTOR. | |
| #define | P99_TSS_LOCAL(NAME) (*(P99_PASTE3(p00_, NAME, _type)*)p99_tss_get_alloc(&(NAME), sizeof(P99_PASTE3(p00_, NAME, _type)))) |
Typedefs | |
| typedef struct p99_tss | p99_tss |
Functions | |
| int | cnd_broadcast (cnd_t *p00_cond) |
| void | cnd_destroy (cnd_t *p00_cond) |
| int | cnd_init (cnd_t *p00_cond) |
| int | cnd_signal (cnd_t *p00_cond) |
| int | cnd_timedwait (cnd_t *restrict p00_cond, mtx_t *restrict p00_mtx, const struct timespec *restrict p00_ts) |
| int | cnd_wait (cnd_t *p00_cond, mtx_t *p00_mtx) |
| void | mtx_destroy (mtx_t *p00_mtx) |
| int | mtx_init (mtx_t *p00_mtx, int p00_type) |
| int | mtx_lock (mtx_t *p00_mtx) |
| int | mtx_timedlock (mtx_t *restrict p00_mtx, const struct timespec *restrict p00_ts) |
| int | mtx_trylock (mtx_t *p00_mtx) |
| int | mtx_unlock (mtx_t *p00_mtx) |
| int | p99_threads_main (int, char *[]) |
A replacement name for the users main function, experimental. | |
| void | p99_tss_delete (p99_tss *p00_key) |
| Similar to tss_delete. | |
| void * | p99_tss_get (p99_tss *p00_key) |
| Similar to tss_get. | |
| void * | p99_tss_get_alloc (p99_tss *p00_key, size_t p00_size) |
| Similar to p99_tss_get, but also allocates a buffer of p00_size bytes for p00_key. | |
| int | p99_tss_set (p99_tss *p00_key, void *p00_val) |
Similar to tss_set(p00_key, p00_val) but also calls the destructor on the previous value if necessary. | |
| int | thrd_create (thrd_t *p00_thr, thrd_start_t p00_func, void *p00_arg) |
| thrd_t | thrd_current (void) |
| int | thrd_detach (thrd_t p00_thr) |
| int | thrd_equal (thrd_t p00_thr0, thrd_t p00_thr1) |
| void | thrd_exit (int p00_res) |
| void | thrd_yield (void) |
| int | tss_create (tss_t *p00_key, tss_dtor_t dtor) |
| void | tss_delete (tss_t p00_key) |
| void * | tss_get (tss_t p00_key) |
| int | tss_set (tss_t p00_key, void *p00_val) |
This is a relatively straightforward implementation of the C11 thread model on top of POSIX threads. The main difficulty this presents is that the thread entry function signature differs between the two. C11 thread returns an int whereas POSIX returns a void*.
You can find the thread management interfaces through the documentation of the type thrd_t.
1.7.6.1
