P99
 All Data Structures Files Functions Variables Typedefs Enumerations Enumerator Friends Defines
p99_atomic.h
Go to the documentation of this file.
00001 /* This may look like nonsense, but it really is -*- mode: C -*-              */
00002 /*        */
00003 /* Except for parts copied from previous work and as explicitly stated below, */
00004 /* the authors and copyright holders for this work are as follows:            */
00005 /* (C) copyright  2011-2013 Jens Gustedt, INRIA, France                       */
00006 /* (C) copyright  2012 William Morris                                         */
00007 /*        */
00008 /* This file is free software; it is part of the P99 project.                 */
00009 /* You can redistribute it and/or modify it under the terms of the QPL as     */
00010 /* given in the file LICENSE. It is distributed without any warranty;         */
00011 /* without even the implied warranty of merchantability or fitness for a      */
00012 /* particular purpose.                                                        */
00013 /*        */
00014 #ifndef P99_ATOMIC_H
00015 #define P99_ATOMIC_H 1
00016
00017 #include "p99_enum.h"
00018 #include "p99_generic.h"
00019
00059 #ifdef P99_TEST_ATOMIC
00060 # undef __GCC_HAVE_SYNC_COMPARE_AND_SWAP_1
00061 # undef __GCC_HAVE_SYNC_COMPARE_AND_SWAP_2
00062 # undef __GCC_HAVE_SYNC_COMPARE_AND_SWAP_4
00063 # undef __GCC_HAVE_SYNC_COMPARE_AND_SWAP_8
00064 #endif
00065
00066 #if defined(__arm__)
00067 # include "p99_atomic_arm.h"
00068 #elif defined(__x86_64__) || defined(__i386__)
00069 # include "p99_atomic_x86.h"
00070 #elif defined(__GNUC__)
00071 # include "p99_atomic_gcc.h"
00072 #else
00073 # warning "no support for atomic operations detected for this platform"
00074 # define P00_NO_ATOMICS
00075 #endif
00076
00081 #if !defined(P00_NO_ATOMICS) || defined(P00_DOXYGEN)
00082
00107 #ifndef ATOMIC_INT8_LOCK_FREE
00108 #  if defined(__GCC_HAVE_SYNC_COMPARE_AND_SWAP_1)
00109 #   define ATOMIC_INT8_LOCK_FREE 2
00110 #   define P00_TYPE_LIST_ELEM1 , (1, uint8_t)
00111 #  else
00112 #   define ATOMIC_INT8_LOCK_FREE 0
00113 #   define P00_TYPE_LIST_ELEM1
00114 #  endif
00115 #endif
00116 #ifndef ATOMIC_INT16_LOCK_FREE
00117 #  if defined(__GCC_HAVE_SYNC_COMPARE_AND_SWAP_2)
00118 #   define ATOMIC_INT16_LOCK_FREE 2
00119 #   define P00_TYPE_LIST_ELEM2 , (2, uint16_t)
00120 #  else
00121 #   define ATOMIC_INT16_LOCK_FREE 0
00122 #   define P00_TYPE_LIST_ELEM2
00123 #  endif
00124 #endif
00125 #ifndef ATOMIC_INT32_LOCK_FREE
00126 #  if defined(__GCC_HAVE_SYNC_COMPARE_AND_SWAP_4)
00127 #   define ATOMIC_INT32_LOCK_FREE 2
00128 #   define P00_TYPE_LIST_ELEM4 , (4, uint32_t)
00129 #  else
00130 #   define ATOMIC_INT32_LOCK_FREE 0
00131 #   define P00_TYPE_LIST_ELEM4
00132 #  endif
00133 #endif
00134 #ifndef ATOMIC_INT64_LOCK_FREE
00135 #  if defined(__GCC_HAVE_SYNC_COMPARE_AND_SWAP_8)
00136 #   define ATOMIC_INT64_LOCK_FREE 2
00137 #   define P00_TYPE_LIST_ELEM8 , (8, uint64_t)
00138 #  else
00139 #   define ATOMIC_INT64_LOCK_FREE 0
00140 #   define P00_TYPE_LIST_ELEM8
00141 #  endif
00142 #endif
00143 #ifndef ATOMIC_INT128_LOCK_FREE
00144 #  if defined(__GCC_HAVE_SYNC_COMPARE_AND_SWAP_16) && (defined(UINT128_MAX) || defined(p99x_uint128))
00145 #   define ATOMIC_INT128_LOCK_FREE 2
00146 #   if defined(UINT128_MAX)
00147 #    define P00_TYPE_LIST_ELEM16 , (16, uint128_t)
00148 #   else
00149 #    define P00_TYPE_LIST_ELEM16 , (16, p99x_uint128)
00150 #   endif
00151 #  else
00152 #   define ATOMIC_INT128_LOCK_FREE 0
00153 #   define P00_TYPE_LIST_ELEM16
00154 #  endif
00155 #endif
00156
00157
00158 #ifndef ATOMIC_BOOL_LOCK_FREE
00159 # if defined(__GCC_HAVE_SYNC_COMPARE_AND_SWAP_4) && (UINT_MAX <= UINT32_MAX)
00160 #define ATOMIC_BOOL_LOCK_FREE 2
00161 # else
00162 #define ATOMIC_BOOL_LOCK_FREE 0
00163 # endif
00164 #endif
00165 #ifndef ATOMIC_CHAR_LOCK_FREE
00166 # define ATOMIC_CHAR_LOCK_FREE ATOMIC_INT8_LOCK_FREE
00167 #endif
00168 #if USHRT_MAX == UINT8_MAX
00169 # define ATOMIC_SHORT_LOCK_FREE ATOMIC_INT8_LOCK_FREE
00170 #elif USHRT_MAX == UINT16_MAX
00171 # define ATOMIC_SHORT_LOCK_FREE ATOMIC_INT16_LOCK_FREE
00172 #elif USHRT_MAX == UINT32_MAX
00173 # define ATOMIC_SHORT_LOCK_FREE ATOMIC_INT32_LOCK_FREE
00174 #elif USHRT_MAX == UINT64_MAX
00175 # define ATOMIC_SHORT_LOCK_FREE ATOMIC_INT64_LOCK_FREE
00176 #elif USHRT_MAX == UINT128_MAX
00177 # define ATOMIC_SHORT_LOCK_FREE ATOMIC_INT128_LOCK_FREE
00178 #else
00179 # define ATOMIC_SHORT_LOCK_FREE 0
00180 #endif
00181 #if UINT_MAX == UINT8_MAX
00182 # define ATOMIC_INT_LOCK_FREE ATOMIC_INT8_LOCK_FREE
00183 #elif UINT_MAX == UINT16_MAX
00184 # define ATOMIC_INT_LOCK_FREE ATOMIC_INT16_LOCK_FREE
00185 #elif UINT_MAX == UINT32_MAX
00186 # define ATOMIC_INT_LOCK_FREE ATOMIC_INT32_LOCK_FREE
00187 #elif UINT_MAX == UINT64_MAX
00188 # define ATOMIC_INT_LOCK_FREE ATOMIC_INT64_LOCK_FREE
00189 #elif UINT_MAX == UINT128_MAX
00190 # define ATOMIC_INT_LOCK_FREE ATOMIC_INT128_LOCK_FREE
00191 #else
00192 # define ATOMIC_INT_LOCK_FREE 0
00193 #endif
00194 #if ULONG_MAX == UINT8_MAX
00195 # define ATOMIC_LONG_LOCK_FREE ATOMIC_INT8_LOCK_FREE
00196 #elif ULONG_MAX == UINT16_MAX
00197 # define ATOMIC_LONG_LOCK_FREE ATOMIC_INT16_LOCK_FREE
00198 #elif ULONG_MAX == UINT32_MAX
00199 # define ATOMIC_LONG_LOCK_FREE ATOMIC_INT32_LOCK_FREE
00200 #elif ULONG_MAX == UINT64_MAX
00201 # define ATOMIC_LONG_LOCK_FREE ATOMIC_INT64_LOCK_FREE
00202 #elif ULONG_MAX == UINT128_MAX
00203 # define ATOMIC_LONG_LOCK_FREE ATOMIC_INT128_LOCK_FREE
00204 #else
00205 # define ATOMIC_LONG_LOCK_FREE 0
00206 #endif
00207 #if ULLONG_MAX == UINT8_MAX
00208 # define ATOMIC_LLONG_LOCK_FREE ATOMIC_INT8_LOCK_FREE
00209 #elif ULLONG_MAX == UINT16_MAX
00210 # define ATOMIC_LLONG_LOCK_FREE ATOMIC_INT16_LOCK_FREE
00211 #elif ULLONG_MAX == UINT32_MAX
00212 # define ATOMIC_LLONG_LOCK_FREE ATOMIC_INT32_LOCK_FREE
00213 #elif ULLONG_MAX == UINT64_MAX
00214 # define ATOMIC_LLONG_LOCK_FREE ATOMIC_INT64_LOCK_FREE
00215 #elif ULLONG_MAX == UINT128_MAX
00216 # define ATOMIC_LLONG_LOCK_FREE ATOMIC_INT128_LOCK_FREE
00217 #else
00218 # define ATOMIC_LLONG_LOCK_FREE 0
00219 #endif
00220 #if UINTPTR_MAX == UINT8_MAX
00221 # define ATOMIC_INTPTR_LOCK_FREE ATOMIC_INT8_LOCK_FREE
00222 #elif UINTPTR_MAX == UINT16_MAX
00223 # define ATOMIC_INTPTR_LOCK_FREE ATOMIC_INT16_LOCK_FREE
00224 #elif UINTPTR_MAX == UINT32_MAX
00225 # define ATOMIC_INTPTR_LOCK_FREE ATOMIC_INT32_LOCK_FREE
00226 #elif UINTPTR_MAX == UINT64_MAX
00227 # define ATOMIC_INTPTR_LOCK_FREE ATOMIC_INT64_LOCK_FREE
00228 #elif UINTPTR_MAX == UINT128_MAX
00229 # define ATOMIC_INTPTR_LOCK_FREE ATOMIC_INT128_LOCK_FREE
00230 #else
00231 # define ATOMIC_INTPTR_LOCK_FREE 0
00232 #endif
00233 #ifndef ATOMIC_POINTER_LOCK_FREE
00234 #define ATOMIC_POINTER_LOCK_FREE ATOMIC_INTPTR_LOCK_FREE
00235 #endif
00236 #if ATOMIC_INTPTR_LOCK_FREE == 2
00237 #if UINTPTR_MAX == UINT8_MAX
00238 # define P00_UINT_TYPE_LIST                                    \
00239   (1, uintptr_t)                                               \
00240   P00_TYPE_LIST_ELEM2                                          \
00241   P00_TYPE_LIST_ELEM4                                          \
00242   P00_TYPE_LIST_ELEM8                                          \
00243   P00_TYPE_LIST_ELEM16
00244 #elif UINTPTR_MAX == UINT16_MAX
00245 # define P00_UINT_TYPE_LIST                                    \
00246   (2, uintptr_t)                                               \
00247   P00_TYPE_LIST_ELEM1                                          \
00248   P00_TYPE_LIST_ELEM4                                          \
00249   P00_TYPE_LIST_ELEM8                                          \
00250   P00_TYPE_LIST_ELEM16
00251 #elif UINTPTR_MAX == UINT32_MAX
00252 # define P00_UINT_TYPE_LIST                                    \
00253   (4, uintptr_t)                                               \
00254   P00_TYPE_LIST_ELEM1                                          \
00255   P00_TYPE_LIST_ELEM2                                          \
00256   P00_TYPE_LIST_ELEM8                                          \
00257   P00_TYPE_LIST_ELEM16
00258 #elif UINTPTR_MAX == UINT64_MAX
00259 # define P00_UINT_TYPE_LIST                                    \
00260   (8, uintptr_t)                                               \
00261   P00_TYPE_LIST_ELEM1                                          \
00262   P00_TYPE_LIST_ELEM2                                          \
00263   P00_TYPE_LIST_ELEM4                                          \
00264   P00_TYPE_LIST_ELEM16
00265 #elif UINTPTR_MAX == UINT128_MAX
00266 # define P00_UINT_TYPE_LIST                                    \
00267   (16, uintptr_t)                                              \
00268   P00_TYPE_LIST_ELEM1                                          \
00269   P00_TYPE_LIST_ELEM2                                          \
00270   P00_TYPE_LIST_ELEM4                                          \
00271   P00_TYPE_LIST_ELEM8
00272 #else
00273 # define P00_UINT_TYPE_LIST                                    \
00274   (1, uint8_t)                                                 \
00275   P00_TYPE_LIST_ELEM2                                          \
00276   P00_TYPE_LIST_ELEM4                                          \
00277   P00_TYPE_LIST_ELEM8                                          \
00278   P00_TYPE_LIST_ELEM16
00279 #endif
00280 #endif
00281 #if UINT_LEAST16_MAX == UINT16_MAX
00282 # define ATOMIC_CHAR16_T_LOCK_FREE ATOMIC_INT16_LOCK_FREE
00283 #elif UINT_LEAST16_MAX == UINT32_MAX
00284 # define ATOMIC_CHAR16_T_LOCK_FREE ATOMIC_INT32_LOCK_FREE
00285 #elif UINT_LEAST16_MAX == UINT64_MAX
00286 # define ATOMIC_CHAR16_T_LOCK_FREE ATOMIC_INT64_LOCK_FREE
00287 #elif UINT_LEAST16_MAX == UINT128_MAX
00288 # define ATOMIC_CHAR16_T_LOCK_FREE ATOMIC_INT128_LOCK_FREE
00289 #else
00290 # define ATOMIC_CHAR16_T_LOCK_FREE 0
00291 #endif
00292 #if UINT_LEAST32_MAX == UINT32_MAX
00293 # define ATOMIC_CHAR32_T_LOCK_FREE ATOMIC_INT32_LOCK_FREE
00294 #elif UINT_LEAST32_MAX == UINT64_MAX
00295 # define ATOMIC_CHAR32_T_LOCK_FREE ATOMIC_INT64_LOCK_FREE
00296 #elif UINT_LEAST32_MAX == UINT128_MAX
00297 # define ATOMIC_CHAR32_T_LOCK_FREE ATOMIC_INT128_LOCK_FREE
00298 #else
00299 # define ATOMIC_CHAR32_T_LOCK_FREE 0
00300 #endif
00301 #if WCHAR_MAX == UINT8_MAX || (!WCHAR_MIN && (WCHAR_MAX == INT8_MAX))
00302 # define ATOMIC_WCHAR_LOCK_FREE ATOMIC_INT8_LOCK_FREE
00303 #elif WCHAR_MAX == UINT16_MAX || (!WCHAR_MIN && (WCHAR_MAX == INT16_MAX))
00304 # define ATOMIC_WCHAR_LOCK_FREE ATOMIC_INT16_LOCK_FREE
00305 #elif WCHAR_MAX == UINT32_MAX || (!WCHAR_MIN && (WCHAR_MAX == INT32_MAX))
00306 # define ATOMIC_WCHAR_LOCK_FREE ATOMIC_INT32_LOCK_FREE
00307 #elif WCHAR_MAX == UINT64_MAX || (!WCHAR_MIN && (WCHAR_MAX == INT64_MAX))
00308 # define ATOMIC_WCHAR_LOCK_FREE ATOMIC_INT64_LOCK_FREE
00309 #elif WCHAR_MAX == UINT128_MAX || (!WCHAR_MIN && (WCHAR_MAX == INT128_MAX))
00310 # define ATOMIC_WCHAR_LOCK_FREE ATOMIC_INT128_LOCK_FREE
00311 #else
00312 # define ATOMIC_WCHAR_LOCK_FREE 0
00313 #endif
00314
00337 P00_DOCUMENT_TYPE_ARGUMENT(P99_UINT_DEFAULT, 0)
00338 #if defined(P00_UINT_TYPE_LIST) || defined(P00_DOXYGEN)
00339 # define P99_UINT_DEFAULT(T)                                                      \
00340 __typeof__(P99_GENERIC_SIZE_LIT(sizeof(T), (uintptr_t){ 0 }, P00_UINT_TYPE_LIST))
00341 #else
00342 # define P00_UINT_TYPE_LIST
00343 # define P99_UINT_DEFAULT(T) uintptr_t
00344 #endif
00345
00350 #define ATOMIC_FLAG_INIT P99_ENC_INIT(0)
00351
00356 #define ATOMIC_VAR_INIT(V) { .p00_xval = { .p00_t = (V), }, }
00357
00372 #ifndef P99_ATOMIC_LOCK_FREE_TYPES
00373 # define P99_ATOMIC_LOCK_FREE_TYPES P00_ATOMIC_LOCK_FREE_TYPES6_
00374
00375 #if ATOMIC_BOOL_LOCK_FREE == 2
00376 # define P00_ATOMIC_LOCK_FREE_TYPES0 _Bool
00377 #endif
00378 #if ATOMIC_CHAR_LOCK_FREE == 2
00379 # define P00_ATOMIC_LOCK_FREE_TYPES1 char, signed char, unsigned char
00380 #endif
00381 #if ATOMIC_SHORT_LOCK_FREE == 2
00382 # define P00_ATOMIC_LOCK_FREE_TYPES2 short, unsigned short
00383 #endif
00384 #if ATOMIC_INT_LOCK_FREE == 2
00385 # define P00_ATOMIC_LOCK_FREE_TYPES3 int, unsigned int
00386 #endif
00387 #if ATOMIC_LONG_LOCK_FREE == 2
00388 # define P00_ATOMIC_LOCK_FREE_TYPES4 long, unsigned long
00389 #endif
00390 #if ATOMIC_LLONG_LOCK_FREE == 2
00391 # define P00_ATOMIC_LOCK_FREE_TYPES5 long long, unsigned long long
00392 #endif
00393 #if ATOMIC_POINTER_LOCK_FREE == 2
00394 # define P00_ATOMIC_LOCK_FREE_TYPES6 char*, signed char*, unsigned char*
00395 #endif
00396
00397 #ifdef P00_ATOMIC_LOCK_FREE_TYPES0
00398 # ifdef P00_ATOMIC_LOCK_FREE_TYPES1
00399 #  define P00_ATOMIC_LOCK_FREE_TYPES1_ P00_ATOMIC_LOCK_FREE_TYPES0, P00_ATOMIC_LOCK_FREE_TYPES1
00400 # else
00401 #  define P00_ATOMIC_LOCK_FREE_TYPES1_ P00_ATOMIC_LOCK_FREE_TYPES0
00402 # endif
00403 #else
00404 # ifdef P00_ATOMIC_LOCK_FREE_TYPES1
00405 #  define P00_ATOMIC_LOCK_FREE_TYPES1_ P00_ATOMIC_LOCK_FREE_TYPES1
00406 # endif
00407 #endif
00408
00409 #ifdef P00_ATOMIC_LOCK_FREE_TYPES1_
00410 # ifdef P00_ATOMIC_LOCK_FREE_TYPES2
00411 #  define P00_ATOMIC_LOCK_FREE_TYPES2_ P00_ATOMIC_LOCK_FREE_TYPES1_, P00_ATOMIC_LOCK_FREE_TYPES2
00412 # else
00413 #  define P00_ATOMIC_LOCK_FREE_TYPES2_ P00_ATOMIC_LOCK_FREE_TYPES1_
00414 # endif
00415 #else
00416 # ifdef P00_ATOMIC_LOCK_FREE_TYPES2
00417 #  define P00_ATOMIC_LOCK_FREE_TYPES2_ P00_ATOMIC_LOCK_FREE_TYPES2
00418 # endif
00419 #endif
00420
00421 #ifdef P00_ATOMIC_LOCK_FREE_TYPES2_
00422 # ifdef P00_ATOMIC_LOCK_FREE_TYPES3
00423 #  define P00_ATOMIC_LOCK_FREE_TYPES3_ P00_ATOMIC_LOCK_FREE_TYPES2_, P00_ATOMIC_LOCK_FREE_TYPES3
00424 # else
00425 #  define P00_ATOMIC_LOCK_FREE_TYPES3_ P00_ATOMIC_LOCK_FREE_TYPES2_
00426 # endif
00427 #else
00428 # ifdef P00_ATOMIC_LOCK_FREE_TYPES3
00429 #  define P00_ATOMIC_LOCK_FREE_TYPES3_ P00_ATOMIC_LOCK_FREE_TYPES3
00430 # endif
00431 #endif
00432
00433 #ifdef P00_ATOMIC_LOCK_FREE_TYPES3_
00434 # ifdef P00_ATOMIC_LOCK_FREE_TYPES4
00435 #  define P00_ATOMIC_LOCK_FREE_TYPES4_ P00_ATOMIC_LOCK_FREE_TYPES3_, P00_ATOMIC_LOCK_FREE_TYPES4
00436 # else
00437 #  define P00_ATOMIC_LOCK_FREE_TYPES4_ P00_ATOMIC_LOCK_FREE_TYPES3_
00438 # endif
00439 #else
00440 # ifdef P00_ATOMIC_LOCK_FREE_TYPES4
00441 #  define P00_ATOMIC_LOCK_FREE_TYPES4_ P00_ATOMIC_LOCK_FREE_TYPES4
00442 # endif
00443 #endif
00444
00445 #ifdef P00_ATOMIC_LOCK_FREE_TYPES4_
00446 # ifdef P00_ATOMIC_LOCK_FREE_TYPES5
00447 #  define P00_ATOMIC_LOCK_FREE_TYPES5_ P00_ATOMIC_LOCK_FREE_TYPES4_, P00_ATOMIC_LOCK_FREE_TYPES5
00448 # else
00449 #  define P00_ATOMIC_LOCK_FREE_TYPES5_ P00_ATOMIC_LOCK_FREE_TYPES4_
00450 # endif
00451 #else
00452 # ifdef P00_ATOMIC_LOCK_FREE_TYPES5
00453 #  define P00_ATOMIC_LOCK_FREE_TYPES5_ P00_ATOMIC_LOCK_FREE_TYPES5
00454 # endif
00455 #endif
00456
00457 #ifdef P00_ATOMIC_LOCK_FREE_TYPES5_
00458 # ifdef P00_ATOMIC_LOCK_FREE_TYPES6
00459 #  define P00_ATOMIC_LOCK_FREE_TYPES6_ P00_ATOMIC_LOCK_FREE_TYPES5_, P00_ATOMIC_LOCK_FREE_TYPES6
00460 # else
00461 #  define P00_ATOMIC_LOCK_FREE_TYPES6_ P00_ATOMIC_LOCK_FREE_TYPES5_
00462 # endif
00463 #else
00464 # ifdef P00_ATOMIC_LOCK_FREE_TYPES6
00465 #  define P00_ATOMIC_LOCK_FREE_TYPES6_ P00_ATOMIC_LOCK_FREE_TYPES6
00466 # endif
00467 #endif
00468 #endif
00469
00470 #ifndef P00_ATOMIC_LOCK_FREE_TYPES6_
00471 # define P00_ATOMIC_LOCK_FREE_TYPES6_
00472 #endif
00473
00484 P99_DECLARE_ENUM(memory_order,
00485                  memory_order_relaxed,
00486                  memory_order_consume,
00487                  memory_order_acquire,
00488                  memory_order_release,
00489                  memory_order_acq_rel,
00490                  memory_order_seq_cst
00491                 );
00492
00493
00518 P99_ENC_DECLARE(uint32_t volatile, atomic_flag);
00519
00520 #define P00_AX(OBJP) ((OBJP)->p00_xval)
00521 #define P00_AT(OBJP) (P00_AX(OBJP).p00_t)
00522 #define P00_AO(OBJP) (P00_AX(OBJP).p00_o)
00523 #define P00_AM(OBJP) (P00_AX(OBJP).p00_m)
00524
00525 P00_DOCUMENT_IDENTIFIER_ARGUMENT(P00_DECLARE_ATOMIC_TYPE, 0)
00526 P00_DOCUMENT_TYPE_ARGUMENT(P00_DECLARE_ATOMIC_TYPE, 1)
00527 P00_DOCUMENT_IDENTIFIER_ARGUMENT(P00_DECLARE_ATOMIC_TYPE, 2)
00528 #define P00_DECLARE_ATOMIC_TYPE(TAGGER, TI, T, NAME)                   \
00529 TAGGER P99_PASTE3(NAME, _, TAGGER) {                                   \
00530   atomic_flag p00_lock;                                                \
00531   union {                                                              \
00532     TI p00_o;                                                          \
00533     P99_UINT_DEFAULT(T) p00_m;                                         \
00534     T p00_t;                                                           \
00535   } p00_xval;                                                          \
00536 };        \
00537 typedef TAGGER P99_PASTE3(NAME, _, TAGGER) P99_PASTE3(NAME, _, TAGGER)
00538
00539
00547 P00_DOCUMENT_TYPE_ARGUMENT(P99_DECLARE_ATOMIC_LOCK_FREE, 0)
00548 P00_DOCUMENT_IDENTIFIER_ARGUMENT(P99_DECLARE_ATOMIC_LOCK_FREE, 1)
00549 #ifdef P00_DOXYGEN
00550 # define P99_DECLARE_ATOMIC_LOCK_FREE(T, NAME)        \
00551  \
00552 typedef P99_PASTE3(p99_, NAME, _union) NAME
00553 #else
00554 #define P99_DECLARE_ATOMIC_LOCK_FREE(T, NAME)                          \
00555 P00_DECLARE_ATOMIC_TYPE(union, T, T, P99_PASTE2(p99_, NAME));          \
00556 P00_DECLARE_ATOMIC_TYPE(struct, uintptr_t, T, P99_PASTE2(p99_, NAME)); \
00557 typedef P99_PASTE3(p99_, NAME, _union) NAME
00558 #endif
00559
00560
00561 #define P00_DECLARE_ATOMIC2(T, ...)        \
00562 P00_DECLARE_ATOMIC_TYPE(union, T, T, P99_PASTE(p99_, __VA_ARGS__));                                                    \
00563 P00_DECLARE_ATOMIC_TYPE(struct, uintptr_t, T, P99_PASTE(p99_, __VA_ARGS__));                                           \
00564  \
00565 typedef P99_PASTE(p99_, __VA_ARGS__, _struct) __VA_ARGS__
00566
00586 P00_DOCUMENT_TYPE_ARGUMENT(P99_DECLARE_ATOMIC, 0)
00587 P00_DOCUMENT_IDENTIFIER_ARGUMENT(P99_DECLARE_ATOMIC, 1)
00588 #ifdef P00_DOXYGEN
00589 #define P99_DECLARE_ATOMIC(T, NAME)
00590 #else
00591 #define P99_DECLARE_ATOMIC(...)        \
00592  \
00593 P99_IF_EQ_1(P99_NARG(__VA_ARGS__))        \
00594 (P00_DECLARE_ATOMIC2(__VA_ARGS__, P99_PASTE2(atomic_, __VA_ARGS__)))                                                   \
00595 (P00_DECLARE_ATOMIC2(__VA_ARGS__))
00596 #endif
00597
00598 #define P00_DECLARE_ATOMIC(T, ...)        \
00599  \
00600 typedef P00_ATOMIC_STRUCT(T, __VA_ARGS__) __VA_ARGS__
00601
00602 #define P00_DECLARE_ATOMIC_CHOICE(MAC, T, NAME)                \
00603 P99_IF_EQ_2(MAC)                                               \
00604 (P99_DECLARE_ATOMIC_LOCK_FREE(T, NAME))                        \
00605 (P99_DECLARE_ATOMIC(T, NAME))
00606
00607
00614 P00_DECLARE_ATOMIC_CHOICE(ATOMIC_INT_LOCK_FREE, int, atomic_int);
00615
00625 P00_DECLARE_ATOMIC_CHOICE(ATOMIC_BOOL_LOCK_FREE, _Bool, atomic_bool);
00626
00627
00628 P00_DECLARE_ATOMIC_CHOICE(ATOMIC_CHAR_LOCK_FREE, char, atomic_char);
00629 P00_DECLARE_ATOMIC_CHOICE(ATOMIC_CHAR_LOCK_FREE, signed char, atomic_schar);
00630 P00_DECLARE_ATOMIC_CHOICE(ATOMIC_CHAR_LOCK_FREE, unsigned char, atomic_uchar);
00631 P00_DECLARE_ATOMIC_CHOICE(ATOMIC_SHORT_LOCK_FREE, short, atomic_short);
00632 P00_DECLARE_ATOMIC_CHOICE(ATOMIC_SHORT_LOCK_FREE, unsigned short, atomic_ushort);
00633 P00_DECLARE_ATOMIC_CHOICE(ATOMIC_INT_LOCK_FREE, unsigned int, atomic_uint);
00634 P00_DECLARE_ATOMIC_CHOICE(ATOMIC_LONG_LOCK_FREE, long, atomic_long);
00635 P00_DECLARE_ATOMIC_CHOICE(ATOMIC_LONG_LOCK_FREE, unsigned long, atomic_ulong);
00636 P00_DECLARE_ATOMIC_CHOICE(ATOMIC_LLONG_LOCK_FREE, long long, atomic_llong);
00637 P00_DECLARE_ATOMIC_CHOICE(ATOMIC_LONG_LOCK_FREE, unsigned long long, atomic_ullong);
00638
00639 P00_DECLARE_ATOMIC_CHOICE(ATOMIC_POINTER_LOCK_FREE, char*, atomic_char_ptr);
00640 P00_DECLARE_ATOMIC_CHOICE(ATOMIC_POINTER_LOCK_FREE, signed char*, atomic_schar_ptr);
00641 P00_DECLARE_ATOMIC_CHOICE(ATOMIC_POINTER_LOCK_FREE, unsigned char*, atomic_uchar_ptr);
00642
00643 P99_DECLARE_ATOMIC(float, atomic_float);
00644 P99_DECLARE_ATOMIC(double, atomic_double);
00645 P99_DECLARE_ATOMIC(long double, atomic_ldouble);
00646
00647 #ifndef __STDC_NO_COMPLEX__
00648 P99_DECLARE_ATOMIC(float _Complex, atomic_cfloat);
00649 P99_DECLARE_ATOMIC(double _Complex, atomic_cdouble);
00650 P99_DECLARE_ATOMIC(long double _Complex, atomic_cldouble);
00651 #define P00_ATOMIC_TYPES                                       \
00652   (_Bool, atomic_bool*),                                       \
00653   (char, atomic_char*),                                        \
00654   (signed char, atomic_schar*),                                \
00655   (unsigned char, atomic_uchar*),                              \
00656   (short int, atomic_short*),                                  \
00657   (unsigned short int, atomic_ushort*),                        \
00658   (int, atomic_int*),                                          \
00659   (unsigned int, atomic_uint*),                                \
00660   (long int, atomic_long*),                                    \
00661   (unsigned long int, atomic_ulong*),                          \
00662   (long long int, atomic_llong*),                              \
00663   (unsigned long long int, atomic_ullong*),                    \
00664   (float, atomic_float*),                                      \
00665   (double, atomic_double*),                                    \
00666   (long double, atomic_ldouble*),                              \
00667   (float _Complex, atomic_cfloat*),                            \
00668   (double _Complex, atomic_cdouble*),                          \
00669   (long double _Complex, atomic_cldouble*)
00670 #else
00671 #define P00_ATOMIC_TYPES                                       \
00672   (_Bool, atomic_bool*),                                       \
00673   (char, atomic_char*),                                        \
00674   (signed char, atomic_schar*),                                \
00675   (unsigned char, atomic_uchar*),                              \
00676   (short int, atomic_short*),                                  \
00677   (unsigned short int, atomic_ushort*),                        \
00678   (int, atomic_int*),                                          \
00679   (unsigned int, atomic_uint*),                                \
00680   (long int, atomic_long*),                                    \
00681   (unsigned long int, atomic_ulong*),                          \
00682   (long long int, atomic_llong*),                              \
00683   (unsigned long long int, atomic_ullong*),                    \
00684   (float, atomic_float*),                                      \
00685   (double, atomic_double*),                                    \
00686   (long double, atomic_ldouble*)
00687 #endif
00688
00689
00690 P00_DOCUMENT_TYPE_ARGUMENT(P99_ATOMIC_INHERIT, 0)
00691 #define P99_ATOMIC_INHERIT(T)                                                               \
00692 (*P99_GENERIC_LIT        \
00693  ((T){ 0 },        \
00694   P99_GENERIC_SIZE_LIT        \
00695   (sizeof(T)+1,        \
00696    (struct P99_PASTE3(p99_atomic_, T, _struct)*){ 0 },                                      \
00697    (1, union P99_PASTE3(p99_atomic_, T, _union)*)                                           \
00698    P99_IF_EQ_2(ATOMIC_INT8_LOCK_FREE)(,(2, union P99_PASTE3(p99_atomic_, T, _union)*))()    \
00699    P99_IF_EQ_2(ATOMIC_INT16_LOCK_FREE)(,(3, union P99_PASTE3(p99_atomic_, T, _union)*))()   \
00700    P99_IF_EQ_2(ATOMIC_INT32_LOCK_FREE)(,(5, union P99_PASTE3(p99_atomic_, T, _union)*))()   \
00701    P99_IF_EQ_2(ATOMIC_INT64_LOCK_FREE)(,(9, union P99_PASTE3(p99_atomic_, T, _union)*))()   \
00702    P99_IF_EQ_2(ATOMIC_INT128_LOCK_FREE)(,(17, union P99_PASTE3(p99_atomic_, T, _union)*))() \
00703    ),        \
00704   P00_ATOMIC_TYPES))
00705
00706 p99_inline
00707 P99_CONST_FUNCTION uintptr_t p00_exchange_ignore(void* p00_x, ...) { P99_UNUSED(p00_x); return 0; }
00708
00709 #define P00_EXCHANGE(X)                                              \
00710 P99_GENERIC_SIZE                                                     \
00711  (sizeof(X),                                                         \
00712   p00_exchange_ignore,                                               \
00713   (1, p00_atomic_exchange_1),                                        \
00714   (2, p00_atomic_exchange_2),                                        \
00715   (4, p00_atomic_exchange_4)                                         \
00716   P99_IF_EQ_2(ATOMIC_INT64_LOCK_FREE)(,(8, p00_atomic_exchange_8))() \
00717   )
00718
00809 #ifdef P00_DOXYGEN
00810 # define _Atomic(T) P99_PASTE2(atomic_, T)
00811 #else
00812 # define _Atomic(T) __typeof__(P99_ATOMIC_INHERIT(T))
00813 #endif
00814
00815 typedef _Atomic(char16_t) atomic_char16_t;
00816 typedef _Atomic(char32_t) atomic_char32_t;
00817 typedef _Atomic(wchar_t) atomic_wchar_t;
00818 typedef _Atomic(int_least8_t) atomic_int_least8_t;
00819 typedef _Atomic(uint_least8_t) atomic_uint_least8_t;
00820 typedef _Atomic(int_least16_t) atomic_int_least16_t;
00821 typedef _Atomic(uint_least16_t) atomic_uint_least16_t;
00822 typedef _Atomic(int_least32_t) atomic_int_least32_t;
00823 typedef _Atomic(uint_least32_t) atomic_uint_least32_t;
00824 typedef _Atomic(int_least64_t) atomic_int_least64_t;
00825 typedef _Atomic(uint_least64_t) atomic_uint_least64_t;
00826 typedef _Atomic(int_fast8_t) atomic_int_fast8_t;
00827 typedef _Atomic(uint_fast8_t) atomic_uint_fast8_t;
00828 typedef _Atomic(int_fast16_t) atomic_int_fast16_t;
00829 typedef _Atomic(uint_fast16_t) atomic_uint_fast16_t;
00830 typedef _Atomic(int_fast32_t) atomic_int_fast32_t;
00831 typedef _Atomic(uint_fast32_t) atomic_uint_fast32_t;
00832 typedef _Atomic(int_fast64_t) atomic_int_fast64_t;
00833 typedef _Atomic(uint_fast64_t) atomic_uint_fast64_t;
00834 typedef _Atomic(intptr_t) atomic_intptr_t;
00835 typedef _Atomic(uintptr_t) atomic_uintptr_t;
00836 typedef _Atomic(size_t) atomic_size_t;
00837 typedef _Atomic(ptrdiff_t) atomic_ptrdiff_t;
00838 typedef _Atomic(intmax_t) atomic_intmax_t;
00839 typedef _Atomic(uintmax_t) atomic_uintmax_t;
00840
00854 p99_inline
00855 void atomic_thread_fence(memory_order p00_ord) {
00856   switch (p00_ord) {
00857   case memory_order_relaxed: break;
00858   default: p00_mfence(); break;
00859   }
00860 }
00861
00866 #define atomic_signal_fence atomic_thread_fence
00867
00884 p99_inline
00885 _Bool atomic_flag_test_and_set_explicit(volatile atomic_flag *p00_objp, memory_order p00_ord) {
00886   _Bool p00_ret;
00887   switch (p00_ord) {
00888     /* This case doesn't require any guarantee. */
00889   case memory_order_relaxed:
00890     p00_ret = P99_ENCP(p00_objp);
00891     P99_ENCP(p00_objp) = 1;
00892     break;
00893     /* For these three the acquire semantics are not sufficient. */
00894   case memory_order_release: ;
00895   case memory_order_acq_rel: ;
00896   case memory_order_seq_cst:
00897     atomic_thread_fence(p00_ord);
00898     p00_ret = p00_sync_lock_test_and_set(&P99_ENCP(p00_objp));
00899     break;
00900   default:
00901     p00_ret = p00_sync_lock_test_and_set(&P99_ENCP(p00_objp));
00902     break;
00903   }
00904   return p00_ret;
00905 }
00906
00913 p99_inline
00914 _Bool atomic_flag_test_and_set(volatile atomic_flag *p00_objp) {
00915   return atomic_flag_test_and_set_explicit(p00_objp, memory_order_seq_cst);
00916 }
00917
00929 p99_inline
00930 void atomic_flag_clear_explicit(volatile atomic_flag *p00_objp, memory_order p00_ord) {
00931   switch(p00_ord) {
00932     /* This case doesn't require any guarantee. */
00933   case memory_order_relaxed:
00934     P99_ENCP(p00_objp) = 0;
00935     break;
00936     /* For these three the release semantics are not sufficient. */
00937   case memory_order_acquire: ;
00938   case memory_order_acq_rel: ;
00939   case memory_order_seq_cst:
00940     p00_sync_lock_release(&P99_ENCP(p00_objp));
00941     atomic_thread_fence(p00_ord);
00942     break;
00943   default:
00944     p00_sync_lock_release(&P99_ENCP(p00_objp));
00945     break;
00946   }
00947 }
00948
00954 p99_inline
00955 void atomic_flag_clear(volatile atomic_flag *p00_objp) {
00956   atomic_flag_clear_explicit(p00_objp, memory_order_seq_cst);
00957 }
00958
00969 p99_inline
00970 void atomic_flag_lock(volatile atomic_flag *p00_objp) {
00971   while (atomic_flag_test_and_set_explicit(p00_objp, memory_order_acquire));
00972 }
00973
00985 p99_inline
00986 _Bool atomic_flag_trylock(volatile atomic_flag *p00_objp) {
00987   return !atomic_flag_test_and_set_explicit(p00_objp, memory_order_acquire);
00988 }
00989
00997 p99_inline
00998 void atomic_flag_unlock(volatile atomic_flag *p00_objp) {
00999   atomic_flag_clear_explicit(p00_objp, memory_order_release);
01000 }
01001
01025 #define P99_SPIN_EXCLUDE(FLAGP)                                             \
01026 P00_BLK_START                                                               \
01027 P00_BLK_DECL(register atomic_flag volatile*const, P99_FILEID(flg), (FLAGP)) \
01028 P00_BLK_BEFAFT(atomic_flag_lock(P99_FILEID(flg)),                           \
01029                atomic_flag_unlock(P99_FILEID(flg)))                         \
01030 P00_BLK_END
01031
01046 #define atomic_is_lock_free(OBJP) (!offsetof(__typeof__(*OBJP), p00_xval))
01047
01048 #define P00_ATOMIC_TERN(OBJP, VAL, ALT) P99_TYPED_TERN(atomic_is_lock_free(OBJP), (VAL), (ALT))
01049
01060 #define atomic_init(OBJP, VAL)                                 \
01061 p99_extension                                                  \
01062 (void)({                                                       \
01063     P99_MAC_ARGS((p00_objp, OBJP), (p00_val, VAL));            \
01064     /* To take care of the atomic_flag and padding bytes. */   \
01065     memset(p00_objp, 0, sizeof *p00_objp);                     \
01066     P00_AT(p00_objp) = p00_val;                                \
01067   })
01068
01069 #ifdef P00_DOXYGEN
01070
01080 #define atomic_exchange(OBJP, DESIRED)
01081 #else
01082 #define atomic_exchange(OBJP, DESIRED)        \
01083 p99_extension        \
01084 ({        \
01085   P99_MACRO_PVAR(p00_objp, (OBJP));        \
01086   register __typeof__(P00_AT(p00_objp)) const p00_des = (DESIRED);                                      \
01087   register __typeof__(P00_AX(p00_objp)) p00_ret = P99_INIT;                                             \
01088   if (!atomic_is_lock_free(p00_objp))        \
01089     P99_SPIN_EXCLUDE(&p00_objp->p00_lock) {                                                             \
01090       p00_ret.p00_t = P00_AT(p00_objp);        \
01091       P00_AT(p00_objp) = p00_des;        \
01092     }        \
01093   P99_IF_EMPTY(P99_ATOMIC_LOCK_FREE_TYPES)                                                              \
01094     ()        \
01095     (else {        \
01096       register __typeof__(P00_AX(p00_objp)) const p00_desm = { .p00_t = p00_des };                      \
01097       switch (sizeof(P00_AT(p00_objp))) {                                                               \
01098       case 1:;        \
01099       case 2:;        \
01100       case 4:;        \
01101       case 8:;        \
01102         p00_ret.p00_m = P00_EXCHANGE(P00_AT(p00_objp))(&P00_AM(p00_objp), p00_desm.p00_m);              \
01103         break;        \
01104       default:        \
01105         p00_ret.p00_m = P00_AM(p00_objp);                                                               \
01106         for (;;) {        \
01107           P99_MACRO_VAR(p00_valm,        \
01108                         __sync_val_compare_and_swap(&P00_AM(p00_objp), p00_ret.p00_m, p00_desm.p00_m)); \
01109           if (P99_LIKELY(p00_valm == p00_ret.p00_m)) break;                                             \
01110           p00_ret.p00_m = p00_valm;        \
01111         }        \
01112       }        \
01113     })        \
01114     p00_ret.p00_t;        \
01115  })
01116 #endif
01117
01126 #define atomic_load(OBJP)                                                         \
01127 p99_extension        \
01128 ({        \
01129   P99_MACRO_PVAR(p00_objp, (OBJP));                                               \
01130   ((!atomic_is_lock_free(p00_objp))                                               \
01131    ? ({        \
01132        register __typeof__(P00_AX(p00_objp).p00_t) p00_ret;                       \
01133        P99_SPIN_EXCLUDE(&p00_objp->p00_lock)                                      \
01134          p00_ret = P00_AT(p00_objp);                                              \
01135        p00_ret;        \
01136      })        \
01137    : (P99_IF_EMPTY(P99_ATOMIC_LOCK_FREE_TYPES)                                    \
01138       (P00_AT(p00_objp))                                                          \
01139       ((__typeof__(P00_AX(p00_objp))){                                            \
01140             .p00_m =                                                              \
01141             P00_ATOMIC_TERN(p00_objp,                                             \
01142                             __sync_val_compare_and_swap(&P00_AM(p00_objp), 0, 0), \
01143                             P00_AM(p00_objp)),                                    \
01144             }).p00_t));                                                           \
01145  })
01146
01147 #define P00_CVT(EXP) ((void const*)(((struct { void const volatile* a; }){ .a = (EXP) }).a))
01148
01165 #define atomic_compare_exchange_weak(OBJP, EXPECTED, DESIRED)                                   \
01166 p99_extension        \
01167 ({        \
01168   P99_MACRO_PVAR(p00_objp, (OBJP));                                                             \
01169   register __typeof__(P00_AT(p00_objp))*const p00_exp = (EXPECTED);                             \
01170   register __typeof__(P00_AT(p00_objp)) const p00_des = (DESIRED);                              \
01171   register _Bool p00_ret = false;                                                               \
01172   if (!atomic_is_lock_free(p00_objp)) {                                                         \
01173     P99_SPIN_EXCLUDE(&p00_objp->p00_lock) {                                                     \
01174       p00_ret = !memcmp(P00_CVT(p00_exp), P00_CVT(&P00_AT(p00_objp)), sizeof P00_AT(p00_objp)); \
01175       /* Both, *EXPECTED and DESIRED must be assignment compatible                              \
01176          with the base type */        \
01177       if (p00_ret) P00_AT(p00_objp) = p00_des;                                                  \
01178       else *p00_exp = P00_AT(p00_objp);                                                         \
01179     }        \
01180   }        \
01181   P99_IF_EMPTY(P99_ATOMIC_LOCK_FREE_TYPES)                                                      \
01182     (else p00_ret = false;)        \
01183     (else {        \
01184       register __typeof__(P00_AM(p00_objp))*const p00_expm                                      \
01185         = (__typeof__(P00_AM(p00_objp))*)P00_ATOMIC_TERN(p00_objp, p00_exp, 0);                 \
01186       register __typeof__(P00_AX(p00_objp)) const p00_desm = { .p00_t = p00_des };              \
01187       register __typeof__(P00_AM(p00_objp)) const p00_valm                                      \
01188         = P00_ATOMIC_TERN        \
01189         (p00_objp,        \
01190          __sync_val_compare_and_swap(&P00_AM(p00_objp), *p00_expm, p00_desm.p00_m),             \
01191          0);        \
01192       p00_ret = (*p00_expm == p00_valm);                                                        \
01193       if (!p00_ret) *p00_expm = p00_valm;                                                       \
01194     })        \
01195     p00_ret;        \
01196  })
01197
01198 #ifdef P00_DOXYGEN
01199
01209 #define atomic_store(OBJP, DES)
01210 #else
01211 #define atomic_store(OBJP, DES) ((void)atomic_exchange(OBJP, DES))
01212 #endif
01213
01214 #define P00_FETCH_OP(OBJP, OPERAND, BUILTIN, OPERATOR)                \
01215 p99_extension                                                         \
01216 ({        \
01217   P99_MACRO_PVAR(p00_objp, (OBJP));                                   \
01218   P99_MACRO_VAR(p00_op, OPERAND);                                     \
01219   ((!atomic_is_lock_free(p00_objp))                                   \
01220    ? ({                                                               \
01221        register __typeof__(P00_AT(p00_objp)) p00_ret;                 \
01222        P99_SPIN_EXCLUDE(&p00_objp->p00_lock) {                        \
01223          p00_ret = P00_AT(p00_objp);                                  \
01224          P00_AT(p00_objp) OPERATOR p00_op;                            \
01225        }                                                              \
01226        p00_ret;                                                       \
01227      })                                                               \
01228    : (P99_IF_EMPTY(P99_ATOMIC_LOCK_FREE_TYPES)                        \
01229       (P00_AT(p00_objp))                                              \
01230       (P00_ATOMIC_TERN(p00_objp,                                      \
01231                        BUILTIN(&P00_AO(p00_objp),                     \
01232                                P00_ATOMIC_TERN(p00_objp, p00_op, 0)), \
01233                        P00_AT(p00_objp)))));                          \
01234  })
01235
01248 #define atomic_fetch_add(OBJP, OPERAND) P00_FETCH_OP((OBJP), (OPERAND), __sync_fetch_and_add, +=)
01249
01250
01263 #define atomic_fetch_sub(OBJP, OPERAND) P00_FETCH_OP((OBJP), (OPERAND), __sync_fetch_and_sub, -=)
01264
01278 #define atomic_fetch_or(OBJP, OPERAND) P00_FETCH_OP((OBJP), (OPERAND), __sync_fetch_and_or, |=)
01279
01293 #define atomic_fetch_and(OBJP, OPERAND) P00_FETCH_OP((OBJP), (OPERAND), __sync_fetch_and_and, &=)
01294
01309 #define atomic_fetch_xor(OBJP, OPERAND) P00_FETCH_OP((OBJP), (OPERAND), __sync_fetch_and_xor, ^=)
01310
01311 #define atomic_fetch_add_conditional(OBJP, OPERAND)                       \
01312 p99_extension                                                             \
01313 ({        \
01314   P99_MACRO_PVAR(p00_objp, (OBJP));                                       \
01315   P99_MACRO_VAR(p00_op, (OPERAND));                                       \
01316   P99_MACRO_VAR(p00_ret, atomic_load(p00_objp));                          \
01317   while (p00_ret) {                                                       \
01318     P99_MACRO_VAR(p00_des, p00_ret + p00_op);                             \
01319     if (atomic_compare_exchange_weak(p00_objp, &p00_ret, p00_des)) break; \
01320   }        \
01321   /* be sure that the result can not be used as an lvalue */              \
01322   register __typeof__(p00_ret = p00_ret) p00_r = p00_ret;                 \
01323   p00_r;        \
01324  })
01325
01326 #define atomic_fetch_max(OBJP, OPERAND)                                  \
01327 p99_extension                                                            \
01328 ({        \
01329   P99_MACRO_PVAR(p00_objp, (OBJP));                                      \
01330   P99_MACRO_VAR(p00_op, (OPERAND));                                      \
01331   P99_MACRO_VAR(p00_ret, atomic_load(p00_objp));                         \
01332   while (p00_ret <= p00_op) {                                            \
01333     if (atomic_compare_exchange_weak(p00_objp, &p00_ret, p00_op)) break; \
01334   }        \
01335   /* be sure that the result can not be used as an lvalue */             \
01336   register __typeof__(p00_ret = p00_ret) p00_r = p00_ret;                \
01337   p00_r;        \
01338  })
01339
01372 P99_BLOCK_DOCUMENT
01373 #define P99_CRITICAL                                                 \
01374 P00_BLK_START                                                        \
01375 P00_BLK_DECL_STATIC(atomic_flag, P99_LINEID(crit), ATOMIC_FLAG_INIT) \
01376 P99_SPIN_EXCLUDE(P99_LINEID(crit))
01377
01382 # endif /* P00_NO_ATOMICS */
01383 #undef P00_NO_ATOMICS
01384
01385 #endif
