P99
◆ P99_SPIN_EXCLUDE
#define P99_SPIN_EXCLUDE (   FLAGP)    P00_SPIN_EXCLUDE(FLAGP, P99_UNIQ(flg))
Protect the following block or statement as a critical section of the program by using FLAGP as a spinlock.
Parameters
FLAGPis an expression that evaluates to a pointer to atomic_flag. The flag is used as a spinlock, so this is an active wait.
Remarks
FLAGP is only evaluated once at the beginning, so it would be safe to change it in the depending block or statement.
Warning
Such a section should only contain a handful of statements.
Such a section should not contain preliminary exits such as goto, break, return, longjmp, or P99_UNWIND etc.
Such a critical section is only protected against threads that try to enter this same critical section. Threads may well simultaneously be in different critical sections.
See also
P99_MUTUAL_EXCLUDE that is more suited for larger sections.
Definition at line 82 of file p99_atomic_flag.h.
