P99
uint8_t p99_small_primes ( size_t  p00_x) [inline]
Return a small prime number or 0 if x is too big.
This is a function implementing a ``static inline'' case table
Default value if p00_x is out of range is 0 .
The table values are 2, 3, 5, 7, 11, 13, 17, 19, 23, 31, 37, 41, 43, 47, 53, 57, 59, 61, 67, 71 .
Parameters:
p00_xindicates the value to choose, it must be compatible with size_t.
Definition at line 47 of file p99_choice.h.
 All Data Structures Files Functions Variables Typedefs Enumerations Enumerator Friends Defines
