00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015 #ifndef P99_INT_H_
00016 # define P99_INT_H_
00017
00036 #include "p99_c99.h"
00037 #include "p99_id.h"
00038 #include "p99_type.h"
00039
00040 #if P99_COMPILER & (P99_COMPILER_GNU | P99_COMPILER_OPEN64)
00041 # if P99_GCC_VERSION >= 40200UL
00042 # pragma GCC diagnostic ignored "-Wmissing-braces"
00043 # endif
00044 #endif
00045
00056 #define P00_DOCUMENT_C2(WIDTH)
00058 #ifdef UINT16_MAX
00059 P00_DOCUMENT_C2(16)
00060 #define P99X_UINT16_C2(H, L) ((((uint16_t)(uint8_t)H) << 8u) | (uint16_t)(uint8_t)L)
00061 #endif
00062 #ifdef INT16_MAX
00063 P00_DOCUMENT_C2(16)
00064 #define P99X_INT16_C2(H, L) ((((int16_t)(int8_t)H) << 8u) | (int16_t)(int8_t)L)
00065 #endif
00066 #ifdef UINT32_MAX
00067 P00_DOCUMENT_C2(32)
00068 #define P99X_UINT32_C2(H, L) ((((uint32_t)(uint16_t)H) << 16u) | (uint32_t)(uint16_t)L)
00069 #endif
00070 #ifdef INT32_MAX
00071 P00_DOCUMENT_C2(32)
00072 #define P99X_INT32_C2(H, L) ((((int32_t)(int16_t)H) << 16u) | (int32_t)(int16_t)L)
00073 #endif
00074 #ifdef UINT64_MAX
00075 P00_DOCUMENT_C2(64)
00076 #define P99X_UINT64_C2(H, L) ((((uint64_t)(uint32_t)H) << 32u) | (uint64_t)(uint32_t)L)
00077 #endif
00078 #ifdef INT64_MAX
00079 P00_DOCUMENT_C2(64)
00080 #define P99X_INT64_C2(H, L) ((((int64_t)(int32_t)H) << 32u) | (int64_t)(int32_t)L)
00081 #endif
00082
00083 #ifdef p99x_uint128
00084 P00_DOCUMENT_C2(128)
00085 #define P99X_UINT128_C2(H, L) ((((p99x_uint128)H) << 64u) | (p99x_uint128)L)
00086 #define P99X_UINT128_0 P99X_UINT128_C2(0x0000000000000000, 0x0000000000000000)
00087 #define P99X_UINT128_MAX P99X_UINT128_C2(0xFFFFFFFFFFFFFFFF, 0xFFFFFFFFFFFFFFFF)
00088 #endif
00089
00090 #ifdef p99x_int128
00091 P00_DOCUMENT_C2(128)
00092 #define P99X_INT128_C2(H, L) ((((p99x_int128)H) << 64u) | (p99x_int128)L)
00093 #define P99X_INT128_MAX P99X_INT128_C2(0x7FFFFFFFFFFFFFFF, 0xFFFFFFFFFFFFFFFF)
00094 #define P99X_INT128_MIN P99X_INT128_C2(0x8000000000000000, 0x0000000000000000)
00095 #endif
00096
00109 #ifndef p99x_uint128
00110 typedef uintmax_t p99x_uintmax;
00111 #endif
00112
00125 #ifndef p99x_int128
00126 typedef intmax_t p99x_intmax;
00127 #endif
00128
00129 #ifdef P00_DOXYGEN
00130
00141 typedef extendedInt p99x_uint128;
00142
00154 typedef extendedInt p99x_int128;
00155 #endif
00156
00157 #ifdef p99x_uintmax
00158
00159 #define P99X__SIGN_PROMOTE(EXPR) \
00160 ((p99x_uintmax)+P99_SIGN_PROMOTE(P99_UE_MAX(EXPR), (p99x_uintmax)+UINTMAX_MAX))
00161
00162 #define P99X__SHIFT(EXPR) \
00163 ((P99_SIGN_PROMOTE(P99_UE_MAX(EXPR), UINTMAX_MAX) > (p99x_uintmax)+UINTMAX_MAX) \
00164 ? 64u \
00165 : 0u)
00166 #endif
00167
00168 #ifndef P99_HIGH2
00169 # if P99_UINTMAX_WIDTH == 64
00170 # define P99_HIGH2(X) \
00171 ((((X) & P00_B0) ? P00_S0 : 0u) \
00172 | (((X) & P00_B1) ? P00_S1 : 0u) \
00173 | (((X) & P00_B2) ? P00_S2 : 0u) \
00174 | (((X) & P00_B3) ? P00_S3 : 0u) \
00175 | (((X) & P00_B4) ? P00_S4 : 0u) \
00176 | (((X) & P00_B5) ? P00_S5 : 0u))
00177 # endif
00178 #endif
00179 #ifndef P99_HIGH2
00180 # if P99_UINTMAX_WIDTH <= 128
00181 # define P99_HIGH2(X) \
00182 ((((X) & P00_B0) ? P00_S0 : 0u) \
00183 | (((X) & P00_B1) ? P00_S1 : 0u) \
00184 | (((X) & P00_B2) ? P00_S2 : 0u) \
00185 | (((X) & P00_B3) ? P00_S3 : 0u) \
00186 | (((X) & P00_B4) ? P00_S4 : 0u) \
00187 | (((X) & P00_B5) ? P00_S5 : 0u) \
00188 | (((X) & P00_B6) ? P00_S6 : 0u))
00189 # endif
00190 #endif
00191
00192 #ifndef P99X__SHIFT
00193 #define P99X__SHIFT(EXPR) 0
00194 #endif
00195
00196 #ifndef P99X__SIGN_PROMOTE
00197 #define P99X__SIGN_PROMOTE(EXPR) 0
00198 #endif
00199
00200 #define P99_HIGH2_1(X) ((X) == P99_UINTMAX_MAX ? P99_UINTMAX_WIDTH : (P99_HIGH2((X) + UINTMAX_C(1))))
00201
00208 P00_DOCUMENT_TYPE_ARGUMENT(P99_TO_UNSIGNED, 0)
00209 P00_DOCUMENT_MACRO_ARGUMENT(P99_TO_UNSIGNED, 1)
00210 #define P99_TO_UNSIGNED(T, MACRO) \
00211 ((uintmax_t) \
00212 (sizeof(T) < sizeof(signed) \
00213 ? (sizeof(T) == 1u \
00214 ? MACRO(unsigned char) \
00215 : MACRO(unsigned short)) \
00216 : (sizeof(T) < sizeof(unsigned long) \
00217 ? MACRO(unsigned) \
00218 : (sizeof(T) < sizeof(unsigned long long) \
00219 ? MACRO(unsigned long) \
00220 : MACRO(unsigned long long)))))
00221
00235 #define P99_M1(T) ((T)-1)
00236
00242 #define P99_M1U(T) (P99_ISSIGNED(T) ? P99_TO_UNSIGNED(T, P99_M1) : P99_C(uintmax_t, P99_M1(T)))
00243
00244 #define P00_DOCUMENT_SIGNED(X)
00245 #define P00_DOCUMENT_UNSIGNED(X)
00278 #define P99_C(T, X) ((T)+(X))
00279
00280 #define P00_DOCUMENT_CONSTANT(T)
00282
00283
00284 #if !defined(SIZE_C)
00285 P00_DOCUMENT_CONSTANT(size_t)
00286 # define SIZE_C(X) P99_C(size_t, X)
00287 #endif
00288
00289 #if !defined(PTRDIFF_C)
00290 P00_DOCUMENT_CONSTANT(ptrdiff_t)
00291 # define PTRDIFF_C(X) P99_C(ptrdiff_t, X)
00292 #endif
00293
00294 #if !defined(WCHAR_C)
00295 P00_DOCUMENT_CONSTANT(wchar_t)
00296 # define WCHAR_C(X) P99_C(wchar_t, X)
00297 #endif
00298
00299 #if !defined(WINT_C)
00300 P00_DOCUMENT_CONSTANT(wint_t)
00301 # define WINT_C(X) P99_C(wint_t, X)
00302 #endif
00303
00304
00305
00306 #if defined(SIG_ATOMIC_MAX) && !defined(SIG_ATOMIC_C)
00307 P00_DOCUMENT_CONSTANT(sig_atomic_t)
00308 # define SIG_ATOMIC_C(X) P99_C(sig_atomic_t, X)
00309 #endif
00310
00311 #if defined(UINTPTR_MAX) && !defined(UINTPTR_C)
00312 P00_DOCUMENT_CONSTANT(uintptr_t)
00313 # define UINTPTR_C(X) P99_C(uintptr_t, X)
00314 #endif
00315
00316 #if defined(UINTPTR_MAX) && !defined(INTPTR_C)
00317 P00_DOCUMENT_CONSTANT(intptr_t)
00318 # define INTPTR_C(X) P99_C(intptr_t, X)
00319 #endif
00320
00321
00322
00323
00324 P00_DOCUMENT_SIGNED(0)
00325 #define P99_0(T) P99_C(T, 0)
00326
00327 P00_DOCUMENT_UNSIGNED(0)
00328 #define P99_0U(T) P99_TO_UNSIGNED(T, P99_0)
00329
00330 P00_DOCUMENT_SIGNED(1)
00331 #define P99_1(T) P99_C(T, 1)
00332
00333 P00_DOCUMENT_UNSIGNED(1)
00334 #define P99_1U(T) P99_TO_UNSIGNED(T, P99_1)
00335
00336 P00_DOCUMENT_SIGNED(2)
00337 #define P99_2(T) P99_C(T, 2)
00338
00339 P00_DOCUMENT_UNSIGNED(2)
00340 #define P99_2U(T) P99_TO_UNSIGNED(T, P99_2)
00341
00342 P00_DOCUMENT_SIGNED(3)
00343 #define P99_3(T) P99_C(T, 3)
00344
00345 P00_DOCUMENT_UNSIGNED(3)
00346 #define P99_3U(T) P99_TO_UNSIGNED(T, P99_3)
00347
00354 P00_DOCUMENT_TYPE_ARGUMENT(P99_UT_MAX, 0)
00355 #define P99_UT_MAX(T) (P99_M1U(T))
00356
00368 #define P99_UT_MAX1(T) (P99_UT_MAX(T)/2u)
00369
00381 #define P00_ST_MIN1(T) (-(T)P99_UT_MAX1(T))
00382
00398 P00_DOCUMENT_TYPE_ARGUMENT(P99_ISSIGNED, 0)
00399 #define P99_ISSIGNED(T) (P99_M1(T) < P99_1(T))
00400
00417 #define P99_SIGN_PROMOTE(A, B) (1 ? (A) : (B))
00418
00419
00420 #define P00_SEE_PROMOTE
00422 #define P00_DOCUMENT_PROMOTE(X)
00424 P00_DOCUMENT_PROMOTE(0)
00425 P00_SEE_PROMOTE
00426 #define P99_PROMOTE_0(EXPR) P99_SIGN_PROMOTE(0, (EXPR))
00427
00428 P00_DOCUMENT_PROMOTE(1)
00429 P00_SEE_PROMOTE
00430 #define P99_PROMOTE_1(EXPR) P99_SIGN_PROMOTE(1, (EXPR))
00431
00432 P00_DOCUMENT_PROMOTE(2)
00433 P00_SEE_PROMOTE
00434 #define P99_PROMOTE_2(EXPR) P99_SIGN_PROMOTE(2, (EXPR))
00435
00436 P00_DOCUMENT_PROMOTE(3)
00437 P00_SEE_PROMOTE
00438 #define P99_PROMOTE_3(EXPR) P99_SIGN_PROMOTE(3, (EXPR))
00439
00440 P00_DOCUMENT_PROMOTE(0U)
00441 P00_SEE_PROMOTE
00442 #define P99_PROMOTE_0U(EXPR) P99_SIGN_PROMOTE(0U, (EXPR))
00443
00444 P00_DOCUMENT_PROMOTE(1u)
00445 P00_SEE_PROMOTE
00446 #define P99_PROMOTE_1U(EXPR) P99_SIGN_PROMOTE(1U, (EXPR))
00447
00448 P00_DOCUMENT_PROMOTE(2u)
00449 P00_SEE_PROMOTE
00450 #define P99_PROMOTE_2U(EXPR) P99_SIGN_PROMOTE(2U, (EXPR))
00451
00452
00453 P00_DOCUMENT_PROMOTE(-1)
00454 P00_SEE_PROMOTE
00455 #define P99_PROMOTE_M1(EXPR) P99_SIGN_PROMOTE(-1, (EXPR))
00456
00461 P00_SEE_PROMOTE
00462 #define P99_PROMOTE_M1U(EXPR) P99_SIGN_PROMOTE(P99_PROMOTE_M1(EXPR), P99_PROMOTE_0U(EXPR))
00463
00470 P00_SEE_PROMOTE
00471 #define P99_UE_MAX(EXPR) (P99_PROMOTE_M1U(EXPR))
00472
00484 P00_SEE_PROMOTE
00485 #define P99_UE_MAX1(EXPR) (P99_UE_MAX(EXPR)/P99_PROMOTE_2U(EXPR))
00486
00487
00488 #ifdef DOXYGEN
00489
00503 P00_SEE_PROMOTE
00504 #define P99_EWIDTH(EXPR)
00505
00509 P00_DOCUMENT_TYPE_ARGUMENT(P99_TMAX, 0)
00510 #define P99_TMAX(T)
00511
00515 P00_DOCUMENT_TYPE_ARGUMENT(P99_TMIN, 0)
00516 #define P99_TMIN(T)
00517
00518 #endif
00519
00520 #ifdef p99x_uintmax
00521 #define P99_EWIDTH(EXPR) \
00522 (P99X__SHIFT(EXPR) \
00523 ? (P99_HIGH2_1((uintmax_t)+(P99_UE_MAX(EXPR)>>P99X__SHIFT(EXPR))) + P99X__SHIFT(EXPR)) \
00524 : P99_HIGH2_1(P99_UE_MAX(EXPR)) \
00525 )
00526 #else
00527 #define P99_EWIDTH(EXPR) P99_HIGH2_1(P99_UE_MAX(EXPR))
00528 #endif
00529
00541 P00_SEE_PROMOTE
00542 #define P99_EPREC(EXPR) (P99_EWIDTH(EXPR) - P99_SIGNED(EXPR))
00543
00558 P00_SEE_PROMOTE
00559 #define P99_EPADDING(EXPR) (sizeof(P99_PROMOTE_0(EXPR))*CHAR_BIT - P99_EWIDTH(EXPR))
00560
00561 #define P99_SE_MAX(EXPR) \
00562 ((((P99_PROMOTE_1(EXPR) \
00563 << (P99_EWIDTH(EXPR) - 2U)) \
00564 - P99_PROMOTE_1(EXPR)) \
00565 << 1U) \
00566 + P99_PROMOTE_1(EXPR))
00567
00568
00580 #define P00_SE_MIN1(EXPR) (-P99_SE_MAX(EXPR))
00581
00597 P00_SEE_PROMOTE
00598 #define P99_SIGNED(EXPR) (P99_PROMOTE_M1(EXPR) < P99_PROMOTE_1(EXPR))
00599
00600
00601 P99_CONST_FUNCTION
00602 p99_inline
00603 uintmax_t p00_abs_signed(intmax_t p00_a) {
00604 uintmax_t p00_aa = p00_a;
00605
00606
00607
00608 return (p00_a < INTMAX_C(0)) ? -p00_aa : p00_a;
00609 }
00610
00624 #define P99_ABS(EXPR) (P99_SIGNED(EXPR) ? p00_abs_signed(EXPR) : P99_C(uintmax_t, EXPR))
00625
00626 #if defined(p99x_uintmax) && defined(p99x_intmax)
00627 P99_CONST_FUNCTION
00628 p99_inline
00629 p99x_uintmax p99x__abs_signed(p99x_intmax p00_a) {
00630 p99x_uintmax p00_aa = p00_a;
00631
00632
00633
00634 return (p00_a < (p99x_intmax)0) ? -p00_aa : p00_a;
00635 }
00636 #define P99X_ABS(EXPR) (P99_SIGNED(EXPR) ? p99x__abs_signed(EXPR) : (EXPR))
00637 #endif
00638
00639 #ifndef P99X_ABS
00640
00650 # define P99X_ABS P00_ABS
00651 #endif
00652
00659 typedef enum {
00660 p99_signed_representation_invalid = 0,
00661 p99_signed_representation_magnitude = 1,
00662 p99_signed_representation_ones = 2,
00663 p99_signed_representation_twos = 3,
00664 } p99_signed_representation;
00665
00674 P00_DOCUMENT_TYPE_ARGUMENT(P99_SIGNED_REPRESENTATION, 0)
00675 #define P99_SIGNED_REPRESENTATION(T) P99_C(p99_signed_representation, (P99_M1(T) & P99_3(T)))
00676
00677
00683 #define P99_2COMPLEMENT(T) (P99_SIGNED_REPRESENTATION(T) == p99_signed_representation_twos)
00684
00685 #ifdef p99x_uintmax
00686 P00_DOCUMENT_TYPE_ARGUMENT(P99_TMAX, 0)
00687 #define P99_TMAX(T) \
00688 ((T) \
00689 (P99X__SHIFT((T)0) \
00690 ? (P99_ISSIGNED(T) ? P99X__SIGN_PROMOTE((T)-1)/2u : P99_UE_MAX((T)0)) \
00691 : (P99_ISSIGNED(T) ? P99_UT_MAX1(T) : P99_UT_MAX(T))))
00692
00693 P00_DOCUMENT_TYPE_ARGUMENT(P99_TMIN, 0)
00694 #define P99_TMIN(T) \
00695 ((T) \
00696 (P99X__SHIFT((T)0) \
00697 ? (P99_ISSIGNED(T) ? (-(P99X__SIGN_PROMOTE((T)-1)/2u)) - P99_2COMPLEMENT(T) : (T)0) \
00698 : (P99_ISSIGNED(T) ? (P00_ST_MIN1(T) - P99_2COMPLEMENT(T)) : P99_0(T))))
00699 #else
00700 P00_DOCUMENT_TYPE_ARGUMENT(P99_TMAX, 0)
00701 #define P99_TMAX(T) P99_C(T, P99_ISSIGNED(T) ? P99_UT_MAX1(T) : P99_UT_MAX(T))
00702 P00_DOCUMENT_TYPE_ARGUMENT(P99_TMIN, 0)
00703 #define P99_TMIN(T) P99_C(T, P99_ISSIGNED(T) ? (P00_ST_MIN1(T) - P99_2COMPLEMENT(T)) : P99_0(T))
00704 #endif
00705
00706
00715 #define P99_E_REPRESENTATION(EXPR) ((p99_signed_representation)(P99_PROMOTE_M1(EXPR) & P99_PROMOTE_3(EXPR)))
00716
00717
00723 #define P99_E_2COMPLEMENT(EXPR) \
00724 P99_SIGN_PROMOTE(P99_E_REPRESENTATION(EXPR) == p99_signed_representation_twos, (EXPR))
00725
00730 #define P99_EMAX(EXPR) (P99_SIGNED(EXPR) ? P99_SE_MAX(EXPR) : P99_PROMOTE_M1(EXPR))
00731
00736 #define P99_EMIN(EXPR) (P99_SIGNED(EXPR) ? (P00_SE_MIN1(EXPR) - P99_E_2COMPLEMENT(EXPR)) : P99_PROMOTE_0(EXPR))
00737
00748 #define P99_TPREC(T) \
00749 (P99X__SHIFT((T)-1) \
00750 ? P99_EPREC((T)-1) \
00751 : P99_HIGH2_1(P99_TMAX(T)))
00752
00765 #define P99_TWIDTH(T) (P99_TPREC(T) + P99_ISSIGNED(T))
00766
00780 #define P99_TPADDING(T) ((sizeof(T)*CHAR_BIT) - P99_TWIDTH(T))
00781
00782 #ifdef P00_DOXYGEN
00783 #define P00_DECLARE_OVERFLOW(SUFF) \
00784 \
00785 \
00786 \
00787 p99_inline \
00788 P99_BUILTIN_TYPE(SUFF,) \
00789 P99_PASTE2(p99_twos, SUFF)(P99_BUILTIN_TYPE(u, SUFF) p00_a); \
00790 p99_inline \
00791 P99_BUILTIN_TYPE(SUFF,) \
00792 P99_PASTE2(p99_add, SUFF)(P99_BUILTIN_TYPE(SUFF,) p00_a, P99_BUILTIN_TYPE(SUFF,) p00_b, int* p00_err)
00793 #else
00794 #define P00_DECLARE_OVERFLOW(SUFF) \
00795 P00_DECLARE_TWOS(SUFF) \
00796 P00_DECLARE_UNSIG(SUFF) \
00797 P00_DECLARE_ADD0(SUFF) \
00798 P00_DECLARE_ADD1(SUFF) \
00799 P00_DECLARE_ADD2(SUFF) \
00800 P00_DECLARE_ADD(SUFF) \
00801 P00_DECLARE_SUB0(SUFF) \
00802 P00_DECLARE_SUB1(SUFF) \
00803 P00_DECLARE_SUB2(SUFF) \
00804 P00_DECLARE_SUB(SUFF) \
00805 P99_MACRO_END(p99_overflow_, SUFF)
00806
00807
00808 #define P00_DECLARE_TWOS(SUFF) \
00809 P99_CONST_FUNCTION \
00810 p99_inline \
00811 P99_BUILTIN_TYPE(SUFF) \
00812 P99_PASTE2(p99_twos, SUFF)(P99_BUILTIN_TYPE(u, SUFF) p00_a) { \
00813 P99_BUILTIN_TYPE(u, SUFF) const type_max = P99_BUILTIN_MAX(SUFF); \
00814 P99_BUILTIN_TYPE(u, SUFF) const type_max1 = (P99_BUILTIN_TYPE(u, SUFF))(type_max + 1); \
00815 \
00816 P99_BUILTIN_TYPE(u, SUFF) const utype_max = (P99_BUILTIN_TYPE(u, SUFF))((2 * type_max) + 1); \
00817 return \
00818
00819
00820 \
00821 (p00_a <= type_max) \
00822 ? p00_a \
00823
00824 \
00825 : (((P99_BUILTIN_MIN(SUFF) == -P99_BUILTIN_MAX(SUFF)) && (p00_a == type_max1)) \
00826 ? (P99_BUILTIN_TYPE(SUFF))(-0) \
00827
00828
00829 \
00830 : (P99_BUILTIN_TYPE(SUFF))((-(P99_BUILTIN_TYPE(SUFF))(utype_max - (utype_max & p00_a))) - 1)); \
00831 }
00832
00833 #define P00_DECLARE_UNSIG(SUFF) \
00834 P99_CONST_FUNCTION \
00835 p99_inline \
00836 P99_BUILTIN_TYPE(u, SUFF) \
00837 P99_PASTE2(p99_unsig, SUFF)(P99_BUILTIN_TYPE(SUFF) p00_a) { \
00838 \
00839 register P99_BUILTIN_TYPE(SUFF) const type_null = 0; \
00840 register P99_BUILTIN_TYPE(u, SUFF) const type_max = P99_BUILTIN_MAX(SUFF); \
00841 register P99_BUILTIN_TYPE(u, SUFF) const type_max1 = (P99_BUILTIN_TYPE(u, SUFF))(type_max + 1); \
00842 \
00843 register P99_BUILTIN_TYPE(u, SUFF) const utype_max = (P99_BUILTIN_TYPE(u, SUFF))((2 * type_max) + 1); \
00844 return \
00845 p00_a >= type_null \
00846 ? p00_a \
00847
00848 \
00849 : (((P99_BUILTIN_MIN(SUFF) == -P99_BUILTIN_MAX(SUFF)) && (p00_a == P99_BUILTIN_MIN(SUFF))) \
00850 ? type_max1 \
00851 \
00852 : (P99_BUILTIN_TYPE(u, SUFF))((utype_max - (P99_BUILTIN_TYPE(u, SUFF))-p00_a) + 1)); \
00853 }
00854
00855 #define P00_DECLARE_ADD0(SUFF) \
00856 P99_CONST_FUNCTION \
00857 p99_inline \
00858 P99_BUILTIN_TYPE(u, SUFF) \
00859 P99_PASTE2(p00_add0, SUFF)(P99_BUILTIN_TYPE(SUFF) p00_a, P99_BUILTIN_TYPE(SUFF) p00_b) { \
00860 register P99_BUILTIN_TYPE(u, SUFF) p00_ua = P99_PASTE2(p99_unsig, SUFF)(p00_a); \
00861 register P99_BUILTIN_TYPE(u, SUFF) p00_ub = P99_PASTE2(p99_unsig, SUFF)(p00_b); \
00862 register P99_BUILTIN_TYPE(u, SUFF) p00_res = (P99_BUILTIN_TYPE(u, SUFF))(p00_ua + p00_ub); \
00863 return p00_res; \
00864 }
00865
00866 #define P00_DECLARE_SUB0(SUFF) \
00867 P99_CONST_FUNCTION \
00868 p99_inline \
00869 P99_BUILTIN_TYPE(u, SUFF) \
00870 P99_PASTE2(p00_sub0, SUFF)(P99_BUILTIN_TYPE(SUFF) p00_a, P99_BUILTIN_TYPE(SUFF) p00_b) { \
00871 register P99_BUILTIN_TYPE(u, SUFF) p00_ua = P99_PASTE2(p99_unsig, SUFF)(p00_a); \
00872 register P99_BUILTIN_TYPE(u, SUFF) p00_ub = P99_PASTE2(p99_unsig, SUFF)(p00_b); \
00873 register P99_BUILTIN_TYPE(u, SUFF) p00_res = (P99_BUILTIN_TYPE(u, SUFF))(p00_ua - p00_ub); \
00874 return p00_res; \
00875 }
00876
00877 #define P00_DECLARE_ADD2(SUFF) \
00878 P99_CONST_FUNCTION \
00879 p99_inline \
00880 P99_BUILTIN_TYPE(SUFF) \
00881 P99_PASTE2(p00_add2, SUFF)(P99_BUILTIN_TYPE(SUFF) p00_a, \
00882 P99_BUILTIN_TYPE(SUFF) p00_b, \
00883 int p00_err[P99_ATLEAST 1]) { \
00884 \
00885 register P99_BUILTIN_TYPE(SUFF) const type_null = 0; \
00886 register P99_BUILTIN_TYPE(u, SUFF) const type_max = P99_BUILTIN_MAX(SUFF); \
00887 register P99_BUILTIN_TYPE(u, SUFF) const type_max1 = (P99_BUILTIN_TYPE(u, SUFF))(type_max + 1); \
00888 register P99_BUILTIN_TYPE(u, SUFF) p00_uc \
00889 = P99_PASTE2(p00_add0, SUFF)(p00_a, p00_b); \
00890 register P99_BUILTIN_TYPE(SUFF) p00_c \
00891 = P99_PASTE2(p99_twos, SUFF)(p00_uc); \
00892 \
00893 if (P99_UNLIKELY(((p00_a ^ p00_b) >= type_null) && ((p00_b ^ p00_c) < type_null)) \
00894 \
00895 || ((P99_BUILTIN_MIN(SUFF) == -P99_BUILTIN_MAX(SUFF)) \
00896 && (p00_uc == type_max1))) \
00897 p00_err[0] = ERANGE; \
00898 return p00_c; \
00899 }
00900
00901 #define P00_DECLARE_SUB2(SUFF) \
00902 P99_CONST_FUNCTION \
00903 p99_inline \
00904 P99_BUILTIN_TYPE(SUFF) \
00905 P99_PASTE2(p00_sub2, SUFF)(P99_BUILTIN_TYPE(SUFF) p00_a, \
00906 P99_BUILTIN_TYPE(SUFF) p00_b, \
00907 int p00_err[P99_ATLEAST 1]) { \
00908 \
00909 register P99_BUILTIN_TYPE(SUFF) const type_null = 0; \
00910 register P99_BUILTIN_TYPE(u, SUFF) const type_max = P99_BUILTIN_MAX(SUFF); \
00911 register P99_BUILTIN_TYPE(u, SUFF) const type_max1 = (P99_BUILTIN_TYPE(u, SUFF))(type_max + 1); \
00912 register P99_BUILTIN_TYPE(u, SUFF) p00_uc \
00913 = P99_PASTE2(p00_sub0, SUFF)(p00_a, p00_b); \
00914 register P99_BUILTIN_TYPE(SUFF) p00_c \
00915 = P99_PASTE2(p99_twos, SUFF)(p00_uc); \
00916 \
00917 if (P99_UNLIKELY(((p00_a ^ p00_b) < type_null) && ((p00_b ^ p00_c) >= type_null)) \
00918 \
00919 || ((P99_BUILTIN_MIN(SUFF) == -P99_BUILTIN_MAX(SUFF)) \
00920 && (p00_uc == type_max1))) \
00921 p00_err[0] = ERANGE; \
00922 return p00_c; \
00923 }
00924
00925 #define P00_DECLARE_ADD1(SUFF) \
00926 P99_CONST_FUNCTION \
00927 p99_inline \
00928 P99_BUILTIN_TYPE(SUFF) \
00929 P99_PASTE2(p00_add1, SUFF)(P99_BUILTIN_TYPE(SUFF) p00_a, \
00930 P99_BUILTIN_TYPE(SUFF) p00_b, \
00931 int p00_err[P99_ATLEAST 1]) { \
00932 \
00933 register P99_BUILTIN_TYPE(SUFF) const type_null = 0; \
00934 register P99_BUILTIN_TYPE(SUFF) p00_ret; \
00935 if (p00_b >= type_null) { \
00936 if (P99_LIKELY(P99_BUILTIN_MAX(SUFF) - p00_b >= p00_a)) { \
00937 p00_ret = p00_a + p00_b; \
00938 } else { \
00939 p00_ret = ((p00_b - P99_BUILTIN_MAX(SUFF)) + p00_a) - 1; \
00940 p00_err[0] = ERANGE; \
00941 } \
00942 } else { \
00943 if (P99_LIKELY(P99_BUILTIN_MIN(SUFF) - p00_b <= p00_a)) { \
00944 p00_ret = p00_a + p00_b; \
00945 } else { \
00946 p00_ret = ((p00_b + P99_BUILTIN_MAX(SUFF)) + p00_a) + 1; \
00947 p00_err[0] = ERANGE; \
00948 } \
00949 } \
00950 return p00_ret; \
00951 }
00952
00953 #define P00_DECLARE_SUB1(SUFF) \
00954 P99_CONST_FUNCTION \
00955 p99_inline \
00956 P99_BUILTIN_TYPE(SUFF) \
00957 P99_PASTE2(p00_sub1, SUFF)(P99_BUILTIN_TYPE(SUFF) p00_a, \
00958 P99_BUILTIN_TYPE(SUFF) p00_b, \
00959 int p00_err[P99_ATLEAST 1]) { \
00960 \
00961 register P99_BUILTIN_TYPE(SUFF) const type_null = 0; \
00962 register P99_BUILTIN_TYPE(SUFF) p00_ret; \
00963 if (p00_b <= type_null) { \
00964 if (P99_LIKELY(P99_BUILTIN_MAX(SUFF) + p00_b >= p00_a)) { \
00965 p00_ret = p00_a - p00_b; \
00966 } else { \
00967 p00_ret = (p00_a - (p00_b + P99_BUILTIN_MAX(SUFF))) + 1; \
00968 p00_err[0] = ERANGE; \
00969 } \
00970 } else { \
00971 if (P99_LIKELY(P99_BUILTIN_MIN(SUFF) + p00_b <= p00_a)) { \
00972 p00_ret = p00_a - p00_b; \
00973 } else { \
00974 p00_ret = (p00_a - (p00_b - P99_BUILTIN_MAX(SUFF))) - 1; \
00975 p00_err[0] = ERANGE; \
00976 } \
00977 } \
00978 return p00_ret; \
00979 }
00980
00981 #define P00_DECLARE_ADD(SUFF) \
00982 P99_CONST_FUNCTION \
00983 p99_inline \
00984 P99_BUILTIN_TYPE(SUFF) \
00985 P99_PASTE2(p99_add, SUFF)(P99_BUILTIN_TYPE(SUFF) p00_a, \
00986 P99_BUILTIN_TYPE(SUFF) p00_b, \
00987 int p00_err[P99_ATLEAST 1]) { \
00988 return \
00989 (P99_BUILTIN_MAX(SUFF) < P99_BUILTIN_MAX(u, SUFF)) \
00990 ? P99_PASTE2(p00_add2, SUFF)(p00_a, p00_b, p00_err) \
00991 : P99_PASTE2(p00_add1, SUFF)(p00_a, p00_b, p00_err); \
00992 }
00993
00994 #define P00_DECLARE_SUB(SUFF) \
00995 P99_CONST_FUNCTION \
00996 p99_inline \
00997 P99_BUILTIN_TYPE(SUFF) \
00998 P99_PASTE2(p99_sub, SUFF)(P99_BUILTIN_TYPE(SUFF) p00_a, \
00999 P99_BUILTIN_TYPE(SUFF) p00_b, \
01000 int p00_err[P99_ATLEAST 1]) { \
01001 return \
01002 (P99_BUILTIN_MAX(SUFF) < P99_BUILTIN_MAX(u, SUFF)) \
01003 ? P99_PASTE2(p00_sub2, SUFF)(p00_a, p00_b, p00_err) \
01004 : P99_PASTE2(p00_sub1, SUFF)(p00_a, p00_b, p00_err); \
01005 }
01006 #endif
01007
01008 P00_DECLARE_OVERFLOW(c);
01009 P00_DECLARE_OVERFLOW(hh);
01010 P00_DECLARE_OVERFLOW(h);
01011 P00_DECLARE_OVERFLOW();
01012 P00_DECLARE_OVERFLOW(l);
01013 P00_DECLARE_OVERFLOW(ll);
01014
01035 #if P99_COMPILER & P99_COMPILER_CLANG
01036 # define P99_INIT \
01037 _Pragma("GCC diagnostic push") \
01038 _Pragma("GCC diagnostic ignored \"-Wmissing-braces\"") \
01039 _Pragma("GCC diagnostic ignored \"-Wmissing-field-initializers\"") \
01040 { 0 } \
01041 _Pragma("GCC diagnostic pop")
01042 #else
01043 # define P99_INIT { 0 }
01044 #endif
01045
01046 #define P00_LVAL1(T) ((T)P99_INIT)
01047 #define P00_LVAL(T, ...) ((T){ __VA_ARGS__ })
01048
01062 #define P99_LVAL(...) P99_IF_LE(P99_NARG(__VA_ARGS__),1)(P00_LVAL1(__VA_ARGS__))(P00_LVAL(__VA_ARGS__))
01063
01064 #ifdef DOXYGEN
01065
01096 # define P99_RVAL(T, VAL)
01097 #else
01098 # define P99_RVAL(...) \
01099 P99_IF_EQ_1(P99_NARG(__VA_ARGS__)) \
01100 (P00_RVAL1(__VA_ARGS__)) \
01101 (P00_RVAL2(__VA_ARGS__))
01102 #endif
01103
01104 #define P00_RVAL1_(T) (((const struct { int p00_bla1; T p00_T1; }){ .p00_bla1 = 0 }).p00_T1)
01105 #define P00_RVAL2_(T) ((( struct { int p00_bla2; T p00_T2; }){ .p00_bla2 = 0 }).p00_T2)
01106
01107 #define P00_RVAL2(T, ...) (P00_RVAL2_(T) = (__VA_ARGS__))
01108 #define P00_RVAL1(T) P00_RVAL2(T, P00_RVAL1_(T))
01109
01129 #define P99_AVAL(T) P00_RVAL2_(T)
01130
01131
01132 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_CHOOSE5, 0)
01133 #define P99_CHOOSE5(xT, cc, cs, ci, cl, cll) \
01134 ((sizeof(xT) < sizeof(int)) \
01135 ? ((sizeof(xT) < sizeof(short)) \
01136 ? cc \
01137 : cs) \
01138 : ((sizeof(xT) <= sizeof(long)) \
01139 ? ((sizeof(xT) == sizeof(int)) \
01140 ? ci \
01141 : cl) \
01142 : cll))
01143
01144
01145 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_PRI, 0)
01146 #define P99_PRI(xT, F, LEN) \
01147 P99_CHOOSE5(xT, \
01148 "%" #LEN "hh" #F, \
01149 "%" #LEN "h" #F, \
01150 "%" #LEN "" #F, \
01151 "%" #LEN "l" #F, \
01152 "%" #LEN "ll" #F)
01153
01158 #define P00_J(X) (0 ? P99_0(uintmax_t) : (X))
01159
01160
01174 #define P99_HMASK(N,M) (P99_PASTE2(P00_MASK_, N)^P99_PASTE2(P00_MASK_, P99_MINUS(N, M)))
01175
01219 #define P99_LOW2(X) ((X) & -(X))
01220
01224 P99_CONST_FUNCTION
01225 p99_inline
01226 uintmax_t p99_low2(uintmax_t p00_x) { return P99_LOW2(p00_x); }
01227
01234 #define P99_LOW2MASK1(X) ((X) ^ ((X) - 1))
01235
01239 P99_CONST_FUNCTION
01240 p99_inline
01241 uintmax_t p99_low2mask1(uintmax_t p00_x) { return P99_LOW2MASK1(p00_x); }
01242
01249 #define P99_LOW2MASK0(X) (~(X) & ((X) - 1))
01250
01254 P99_CONST_FUNCTION
01255 p99_inline
01256 uintmax_t p99_low2mask0(uintmax_t p00_x) { return P99_LOW2MASK0(p00_x); }
01257
01264 #define P99_MASK2LOW1(X) ((X) | -(X))
01265
01269 P99_CONST_FUNCTION
01270 p99_inline
01271 uintmax_t p99_mask2low1(uintmax_t p00_x) { return P99_MASK2LOW1(p00_x); }
01272
01279 #define P99_MASK2LOW0(X) ((X) ^ -(X))
01280
01284 P99_CONST_FUNCTION
01285 p99_inline
01286 uintmax_t p99_mask2low0(uintmax_t p00_x) { return P99_MASK2LOW0(p00_x); }
01287
01293 #define P99_LOW2CLEAR(X) ((X) & ((X) - 1))
01294
01298 P99_CONST_FUNCTION
01299 p99_inline
01300 uintmax_t p99_low2clear(uintmax_t p00_x) { return P99_LOW2CLEAR(p00_x); }
01301
01307 #define P99_LOW2FILL(X) ((X) | ((X) - 1))
01308
01312 P99_CONST_FUNCTION
01313 p99_inline
01314 uintmax_t p99_low2fill(uintmax_t p00_x) { return P99_LOW2FILL(p00_x); }
01315
01321 #define P99_LOW0SET(X) ((X) | ((X) + 1))
01322
01326 P99_CONST_FUNCTION
01327 p99_inline
01328 uintmax_t p99_low0set(uintmax_t p00_x) { return P99_LOW0SET(p00_x); }
01329
01336 #define P99_LOW2SHIFT(X) (P99_LIKELY(!!(X)) ? ((X) / ((X) & -(X))) : 0u)
01337
01341 P99_CONST_FUNCTION
01342 p99_inline
01343 uintmax_t p99_low2shift(uintmax_t p00_x) { return P99_LOW2SHIFT(p00_x); }
01344
01353 P99_CONST_FUNCTION
01354 p99_inline
01355 uintmax_t p99_next_popcount(uintmax_t p00_x) {
01356 uintmax_t p00_ret = 0;
01357 if (p00_x) {
01358 uintmax_t p00_b = P99_LOW2(p00_x);
01359 uintmax_t p00_t = p00_x + p00_b;
01360 uintmax_t p00_c = p00_x ^ p00_t;
01361 uintmax_t p00_m = (p00_c >> 2) / p00_b;
01362 p00_ret = p00_t | p00_m;
01363 }
01364 return p00_ret;
01365 }
01366
01378 P99_DECLARE_UNION(p00_endian_2);
01380 P99_DECLARE_UNION(p00_endian_4);
01382 P99_DECLARE_UNION(p00_endian_8);
01384 P99_DECLARE_UNION(p00_endian_16);
01385
01386 typedef uint16_t p00_uint_byte_2;
01387 typedef uint32_t p00_uint_byte_4;
01388 typedef uint64_t p00_uint_byte_8;
01389
01390 union p00_endian_2 {
01391 uint8_t p00_c[2];
01392 uint16_t p00_i;
01393 };
01394
01395 union p00_endian_4 {
01396 uint8_t p00_c[4];
01397 uint32_t p00_i;
01398 };
01399
01400 union p00_endian_8 {
01401 uint8_t p00_c[8];
01402 uint64_t p00_i;
01403 };
01404
01405
01406 #ifdef UINT128_MAX
01407 typedef uint128_t p00_uint_byte_16;
01408
01409 union p00_endian_16 {
01410 uint8_t p00_c[16];
01411 uint128_t p00_i;
01412 };
01413 #else
01414 # ifdef p99x_uint128
01415 typedef p99x_uint128 p00_uint_byte_16;
01416
01417 union p00_endian_16 {
01418 uint8_t p00_c[16];
01419 p99x_uint128 p00_i;
01420 };
01421 # endif
01422 #endif
01423
01424
01425 #define P00_HTON0(N, X, I) [I] = (0xFF & ((X)>>((N - (I + 1))*CHAR_BIT)))
01426 #define P00_HTON(N, X) P99_FOR(N, N, P00_SEQ, P00_HTON0, P99_DUPL(N, X))
01427 #define P99_HTON_INITIALIZER(N, X) { .p00_c = { P00_HTON(N, X) } }
01428
01434 #define P99_HTON(N, X) (((P99_PASTE2(p00_endian_, N) const)P99_HTON_INITIALIZER(N, X)).p00_i)
01435
01442 P00_DOCUMENT_NUMBER_ARGUMENT(P99_HTONS, 0)
01443 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_HTONS, 1)
01444 #define P99_HTONS(X) P99_HTON(2, X)
01445
01452 P00_DOCUMENT_NUMBER_ARGUMENT(P99_HTONL, 0)
01453 P00_DOCUMENT_PERMITTED_ARGUMENT(P99_HTONL, 1)
01454 #define P99_HTONL(X) P99_HTON(4, X)
01455
01456
01457 #define P00_NTOH0(N, X, I) (((P99_PASTE2(p00_uint_byte_, N))((X).p00_c[I]))<<((N - (I + 1))*CHAR_BIT))
01458 #define P00_NTOH(N, X, XX) P99_FOR(N, N, P00_BOR, P00_NTOH0, P99_DUPL(N, XX))
01459 #define P99_NTOH_INITIALIZER(N, X) { .p00_i = (X) }
01460
01466 #define P99_NTOH(N, X) (P99_PASTE2(p00_uint_byte_, N) const)P00_NTOH(N, X, ((P99_PASTE2(p00_endian_, N) const)P99_NTOH_INITIALIZER(N, X)))
01467
01474 P00_DOCUMENT_NUMBER_ARGUMENT(P99_NTOHS, 0)
01475 #define P99_NTOHS(X) P99_NTOH(2, X)
01476
01483 P00_DOCUMENT_NUMBER_ARGUMENT(P99_NTOHL, 0)
01484 #define P99_NTOHL(X) P99_NTOH(4, X)
01485
01486
01487
01497 #endif
