00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024 #ifndef P99_STR_H_
00025 # define P99_STR_H_
00026
00034 #include "p99_classification.h"
00035
00036 #define P00_DEFINE_STR3(CODE) \
00037 p99_inline \
00038 P99_BUILTIN_TYPE(CODE) P99_PASTE2(str2, CODE)(char const* p00_nptr, size_t* p00_pos, unsigned p00_base) { \
00039 char *p00_eptr; \
00040 P99_BUILTIN_TYPE(CODE) p00_ret = (strto ## CODE)(p00_nptr, (p00_pos ? &p00_eptr : 0), p00_base); \
00041 if (p00_pos) *p00_pos = p00_eptr - p00_nptr; \
00042 return p00_ret; \
00043 } \
00044 P99_MACRO_END(P00_DEFINE_STR3, CODE)
00045
00046 #define P00_STR3_0(X) P00_DEFINE_STR3(X)
00047 #define P00_STR3_1(...) P99_SEP(P00_STR3_0, __VA_ARGS__)
00048
00049 #ifndef P00_DOXYGEN
00050 P00_STR3_1(l, ll, ul, ull, uz, t, j, uj);
00051 #endif
00052
00053 P00_C99_DEFARG_DOCU(str2l, long, char const *p00_nptr, size_t *p00_pos, unsigned p00_base)
00057 #define str2l(...) P99_CALL_DEFARG(str2l, 3, __VA_ARGS__)
00058 #define str2l_defarg_1() 0
00059 #define str2l_defarg_2() 0
00060
00061 P00_C99_DEFARG_DOCU(str2ll, long long, char const *p00_nptr, size_t *p00_pos, unsigned p00_base)
00065 #define str2ll(...) P99_CALL_DEFARG(str2ll, 3, __VA_ARGS__)
00066 #define str2ll_defarg_1() 0
00067 #define str2ll_defarg_2() 0
00068
00069 P00_C99_DEFARG_DOCU(str2ul, unsigned long, char const *p00_nptr, size_t *p00_pos, unsigned p00_base)
00073 #define str2ul(...) P99_CALL_DEFARG(str2ul, 3, __VA_ARGS__)
00074 #define str2ul_defarg_1() 0
00075 #define str2ul_defarg_2() 0
00076
00077 P00_C99_DEFARG_DOCU(str2ull, unsigned long long, char const *p00_nptr, size_t *p00_pos, unsigned p00_base)
00081 #define str2ull(...) P99_CALL_DEFARG(str2ull, 3, __VA_ARGS__)
00082 #define str2ull_defarg_1() 0
00083 #define str2ull_defarg_2() 0
00084
00085 P00_C99_DEFARG_DOCU(str2uz, size_t, char const *p00_nptr, size_t *p00_pos, unsigned p00_base)
00089 #define str2uz(...) P99_CALL_DEFARG(str2uz, 3, __VA_ARGS__)
00090 #define str2uz_defarg_1() 0
00091 #define str2uz_defarg_2() 0
00092
00093 P00_C99_DEFARG_DOCU(str2t, ptrdiff_t, char const *p00_nptr, size_t *p00_pos, unsigned p00_base)
00097 #define str2t(...) P99_CALL_DEFARG(str2t, 3, __VA_ARGS__)
00098 #define str2t_defarg_1() 0
00099 #define str2t_defarg_2() 0
00100
00101 P00_C99_DEFARG_DOCU(str2j, intmax_t, char const *p00_nptr, size_t *p00_pos, unsigned p00_base)
00105 #define str2j(...) P99_CALL_DEFARG(str2j, 3, __VA_ARGS__)
00106 #define str2j_defarg_1() 0
00107 #define str2j_defarg_2() 0
00108
00109 P00_C99_DEFARG_DOCU(str2uj, uintmax_t, char const *p00_nptr, size_t *p00_pos, unsigned p00_base)
00113 #define str2uj(...) P99_CALL_DEFARG(str2uj, 3, __VA_ARGS__)
00114 #define str2uj_defarg_1() 0
00115 #define str2uj_defarg_2() 0
00116
00117 #define P00_DEFINE_STR2(CODE) \
00118 p99_inline \
00119 P99_BUILTIN_TYPE(CODE) P99_PASTE2(str2, CODE)(char const* p00_nptr, size_t* p00_pos) { \
00120 char *p00_eptr; \
00121 P99_BUILTIN_TYPE(CODE) p00_ret = (strto ## CODE)(p00_nptr, (p00_pos ? &p00_eptr : 0)); \
00122 if (p00_pos) *p00_pos = p00_eptr - p00_nptr; \
00123 return p00_ret; \
00124 } \
00125 P99_MACRO_END(P00_DEFINE_STR2, CODE)
00126
00127 #define P00_STR2_0(X) P00_DEFINE_STR2(X)
00128 #define P00_STR2_1(...) P99_SEP(P00_STR2_0, __VA_ARGS__)
00129
00130 P00_STR2_1(f, d, ld);
00131
00132 P00_C99_DEFARG_DOCU(str2f, float, char const *p00_nptr, size_t *p00_pos)
00135 #define str2f(...) P99_CALL_DEFARG(str2f, 2, __VA_ARGS__)
00136 #define str2f_defarg_1() 0
00137
00138 P00_C99_DEFARG_DOCU(str2d, double, char const *p00_nptr, size_t *p00_pos)
00141 #define str2d(...) P99_CALL_DEFARG(str2d, 2, __VA_ARGS__)
00142 #define str2d_defarg_1() 0
00143
00144 P00_C99_DEFARG_DOCU(str2ld, long double, char const *p00_nptr, size_t *p00_pos)
00147 #define str2ld(...) P99_CALL_DEFARG(str2ld, 2, __VA_ARGS__)
00148 #define str2ld_defarg_1() 0
00149
00150
00151
00152 #endif
