P99
test-p99-conformance.c
A file that provides a test for C99 conformance. It only tests the "compiler" part of C, that is without any include files. Any C implementation, whether hosted or freestanding should comply with this.
To convince your compiler to compile this you might have to provide some additional parameters on the command line. E.g for the gcc family of compilers (including third party pretenders) you usually have to give "-std=c99" to switch to C99 mode. But other parameters may be in order, consult your compiler documentation.
This file is split into several parts that hopefully are self explanatory. Each of the parts has a macro SKIP_... that lets you skip a test.
/* This may look like nonsense, but it really is -*- mode: C; coding: utf-8 -*- */
/* Except of parts copied from previous work and as explicitly stated below, */
/* the author and copyright holder for this work is                          */
/* (C) copyright  2011 Jens Gustedt, INRIA, France                           */
/* This file is free software; it is part of the P99 project.                */
/* You can redistribute it and/or modify it under the terms of the QPL as    */
/* given in the file LICENSE. It is distributed without any warranty;        */
/* without even the implied warranty of merchantability or fitness for a     */
/* particular purpose.                                                       */
#ifndef SKIP_VA_ARGS_MACRO
# define FIRST(X, ...) X
# if FIRST(0, something)
#  error "The preprocessor lacks variable argument list support. Run test with -DSKIP_VA_ARGS_MACRO to be able to see the other tests."
# endif
#endif
#ifndef SKIP_BOOL
enum { hasTrue = (_Bool)127, hasFalse = (_Bool)0 };
_Bool has_Bool[1];
_Bool has_Bool[hasTrue] = { hasFalse };
#endif
#ifndef SKIP_VLA
double has_VLA_function(unsigned n, double A[n][n]) {
  double ret = 0.0;
  unsigned i, j;
  for (i = 0; i < n; ++i)
    for (j = 0; j < n; ++j)
      ret += A[i][j];
  return ret;
double has_VLA(unsigned n) {
  double VLA[n][n];
  return has_VLA_function(n, VLA);
#endif
#ifndef SKIP_INLINE
typedef void (*func)(void);
/* This alone should not result in a generation of a symbol
   "has_undefined_symbol1". It should even not have an entry as
   "undefined" in the symbol table, but such an entry would be
   tolerable. */
inline
void
has_undefined_symbol1(void) {
  /* empty */
   "undefined_symbol2" but insert an "undefined" symbol to such a
   function in the symbol table. */
inline
void
has_undefined_symbol2(void) {
  /* empty */
func undefined_symbol2_tester[] = { has_undefined_symbol2 };
/* This should result in a generation of a symbol has_mandatory_symbol1 */
inline
void
has_mandatory_symbol1(void) {
  /* empty */
extern inline
void
has_mandatory_symbol1(void);
/* This should result in a generation of a symbol has_mandatory_symbol2 */
inline
void
has_mandatory_symbol2(void) {
  /* empty */
func mandatory_symbol2_tester[] = { has_mandatory_symbol2 };
extern inline
void
has_mandatory_symbol2(void);
/* This should result in a generation of a symbol has_mandatory_symbol3 */
inline
void
has_mandatory_symbol3(void) {
  /* empty */
void
has_mandatory_symbol3(void);
/* This should result in a generation of a symbol has_mandatory_symbol4 */
inline
void
has_mandatory_symbol4(void) {
  /* empty */
func mandatory_symbol4_tester[] = { has_mandatory_symbol4 };
extern inline
void
has_mandatory_symbol4(void);
#endif
#ifndef SKIP_HEXDOUBLE
enum { hasHexdouble = (0x1P2 > 10) };
double has_hexdouble[hasHexdouble];
#endif
#ifndef SKIP_COMPOUND
unsigned has_compound_literal(void) {
  return (unsigned){ 0 };
#endif
#ifndef SKIP_INITIALIZERS
unsigned has_designated_array_initializer[4] = { [3] = 1u };
unsigned A1[] = { [3] = 1u };
unsigned has_length_from_initializer[sizeof(has_designated_array_initializer) == sizeof(A1)];
struct {
  unsigned first;
  double second;
} has_designated_struct_initializer = { .second = 1, .first = 2 };
#endif
#define GLUE2(A, B) A ## B
#define CONCAT2(A, B) GLUE2(A, B)
#define STRINGIFY(A) STRINGIFY_(A)
#define STRINGIFY_(A) #A
#ifndef SKIP_TOKEN_CONCAT
double has_concat_of_floats_1E = CONCAT2(1E, 3);
double has_concat_of_floats_1Ep = CONCAT2(1E+, 3);
/* This one should iteratively compose a double value from left to
   right. */
# ifndef SKIP_TOKEN_CONCAT_ITERATIVE
double has_concat_of_floats_iterative = CONCAT2(CONCAT2(CONCAT2(1, E), +), 3);
# endif
/* These ones are tricky. The terms inside the STRINGIFY should lead to
   valid preprocessing tokens but which are invalid tokens for the
   following phases. */
char const has_concat_of_floats_1Ep3Em[] = STRINGIFY(CONCAT2(CONCAT2(1E+, 3E-), 3));
# ifndef SKIP_TOKEN_HASH_HASH_AS_ARGUMENT
#define DONT_CONCAT_(X) A X B
#define DONT_CONCAT(X) DONT_CONCAT_(X)
char const has_hash_hash_as_argument[] = STRINGIFY(DONT_CONCAT(##));
# endif
# ifndef SKIP_TOKEN_CONCAT_HASH_HASH
char const has_concat_of_hash_hash[] = STRINGIFY(CONCAT2(#, #));
# endif
# ifndef SKIP_STRINGIFY_EMPTY
char const has_stringify_empty[] = STRINGIFY();
# endif
#endif
#ifndef SKIP_EXPANDS
/* expand arguments after assigment, but before call */
# define COMMA ,
# define GLUE1(X) GLUE2(X)
# define CONCAT3(A, B, C) GLUE2(A, B C)
# define GLUE3(A, B, C) A ## B ## C
unsigned has_determines_macro_arguments_first[GLUE1(0 COMMA 1)];
/* Expand args before ## concatenation? The rules for this are
   subtle. */
# define EATEAT 0
# define EAT 1
enum { CONCAT2(eat, GLUE2(EAT, EAT)) = GLUE2(EAT, EAT),
       CONCAT2(eat, CONCAT2(EAT, EAT)) = CONCAT2(EAT, EAT),
       /* Only replace the empty argument by a placeholder if it is
          preceded or followed by a ## in the replacement text. */
       eat2 = CONCAT3(EAT,,EAT),
       eat3 = GLUE3(EAT,,EAT),
unsigned has_preprocessor_expands_before_concatenation1[(eat0 == 0)*2 - 1] = { eat0 };
unsigned has_preprocessor_expands_before_concatenation2[(eat11 == 11)*2 - 1] = { eat0 };
unsigned has_preprocessor_no_placeholder_on_recursion[(eat2 == 11)*2 - 1] = { eat0 };
unsigned has_preprocessor_placeholder[(eat3 == 0)*2 - 1] = { eat0 };
#endif
#ifndef SKIP_TRAILING_COMMA
enum { enumConstant, } has_enum_trailing_commas;
unsigned has_initializer_trailing_commas[] = { 0, };
#endif
#ifndef SKIP_FLEXIBLE
typedef struct {
  unsigned len;
  double arr[];
} flexible;
typedef union {
  flexible flex;
  char buffer[sizeof(flexible) + 10*sizeof(double)];
} flex10;
flex10 has_flexible_array = { .flex.len = 10 };
#endif
#ifndef SKIP_RESTRICT
char restrict_buffer[25];
char *restrict has_restrict_keyword = restrict_buffer;
#endif
#ifndef SKIP_STATIC_PARAMETER
void has_static_parameter(double A[static 10]){
 /* empty */
#endif
#ifndef SKIP_CONST_PARAMETER
void has_const_parameter(double A[const 10]){
 /* empty */
#endif
#ifndef SKIP_VOLATILE_PARAMETER
void has_volatile_parameter(double A[volatile 10]){
 /* empty */
#endif
#ifndef SKIP_RESTRICT_PARAMETER
# ifndef SKIP_RESTRICT
void has_restrict_parameter(double A[restrict 10]){
 /* empty */
# endif
#endif
#ifndef SKIP_COMMENTS
enum { hasCppComment = -2
       + 3
       //* for C99 all of this is a comment to the end of the line */ 3
       /* for C89 this resolves in division by 3 */
unsigned has_cpp_comment[hasCppComment];
#endif
#ifndef SKIP_MIXED
unsigned has_mixed_declaration(void) {
  /* infinite recursion, but who cares */
  has_mixed_declaration();
  unsigned a = 10;
  return a;
#endif
#ifndef SKIP_FOR_DECLARATION
unsigned has_for_declaration(void) {
  unsigned a = 10;
  for (unsigned i = 0; i < a; ++i) {
    a -= i;
  switch (0)
    for (unsigned var; 0;)
    default:
      switch((var = 0), 0)
      default: {
        return var;
  return a;
#endif
#ifndef SKIP_IDEM
unsigned const const has_idempotent_const = 1;
unsigned volatile volatile has_idempotent_volatile = 1;
unsigned *restrict restrict has_idempotent_restrict = 0;
# endif
#endif
#ifndef SKIP_PRAGMA
# pragma STDC FP_CONTRACT ON
# define PRAGMA(MESS) _Pragma(# MESS)
PRAGMA(STDC FP_CONTRACT OFF)
#endif
#ifndef SKIP_FUNC
void has_func_macro(char const* where[]) {
  *where = __func__;
#endif
#ifndef SKIP_LONG_LONG
long long has_long_long = 0;
unsigned long long has_ullong_max[-1 + 2*((0ULL - 1) >= 18446744073709551615ULL)];
#endif
#ifndef SKIP_LONG_DOUBLE
long double has_long_double = 1.0L;
#endif
#ifndef SKIP_PREPRO_ARITH
# if (0 - 1) >= 0
#  error "this should be a negative value"
# else
unsigned const has_preprocessor_minus = 1;
# endif
/* Unsigned arithmetic should be done in the type that corresponds to
   uintmax_t and it should use modulo arithmetic. */
# if ~0U < 0
#  error "this should be a large positive value"
# endif
# if ~0U != (0U - 1)
#  error "the preprocessor should do modulo arithmetic on unsigned values"
# endif
unsigned const has_preprocessor_bitneg = 1;
# if (~0U < 65535)
#  error "this should be a large positive value, at least UINT_MAX >= 2^{16} - 1"
# endif
# if (~0U < 4294967295)
#  error "this should be a large positive value, at least ULONG_MAX >= 2^{32} - 1"
# endif
# if (~0U < 18446744073709551615ULL)
#  error "this should be a large positive value, at least ULLONG_MAX >= 2^{64} - 1"
# endif
unsigned has_preprocessor_uintmax;
# if (1 ? -1 : 0U) < 0
#  warning "ternary operator should promote to unsigned value"
# else
unsigned const has_preprocessor_ternary_unsigned = 1;
# endif
# if (1 ? -1 : 0) > 0
#  warning "ternary operator should result in signed value"
# else
unsigned const has_preprocessor_ternary_signed = 1;
# endif
/* Bool operation should return a signed integer */
# if (1 ? -1 : (0 && 0)) > 0
#  error "logical operations should return signed values"
#endif
# if (1 ? -1 : (0U && 0)) > 0
#endif
# if (1 ? -1 : (0 && 0U)) > 0
#endif
# if (1 ? -1 : (0U && 0U)) > 0
#endif
unsigned const has_preprocessor_logical_signed = 1;
#endif
/* A comma operator shall not appear in a constant expression, unless
   it is not evaluated. First test for the good case: it isn't
   evaluated. First this should be accepted by the compiler but also
   it should do the correct type promotions. This test can have
   different results when we try this for constant expressions in the
   compiler phase or in the preprocessor phase. */
#define GOOD ((1 ? -1 : (0, 0u)) < 0 )
#ifndef SKIP_NON_EVALUATED_COMMA_ASSIGN
unsigned const has_non_evaluated_comma_expression_assign[2*!GOOD - 1] = { 0 };
#endif
#ifndef SKIP_NON_EVALUATED_COMMA_PREPRO
# if GOOD
#  warning "non evaluated comma expression yields wrong result"
# else
unsigned const has_non_evaluated_comma_expression_prepro = GOOD;
# endif
#endif
/* Now if it is in the evaluated part, this is undefined
   behavior. This could lead to anything, but also to the nice
   behavior that the compiler tells us. Some compilers do tell us in
   fact, but only as a warning. Some just refuse to compile. */
#define BAD ((0 ? -1 : (0, 0u)) > -1 )
#ifndef SKIP_EVALUATED_COMMA_ASSIGN
enum { bad = BAD };
#else
unsigned const has_evaluated_comma_expression_assign = 1;
#endif
#ifndef SKIP_EVALUATED_COMMA_PREPRO
# if BAD
#  warning "evaluated comma expression yields wrong result"
# endif
#else
unsigned const has_evaluated_comma_expression_prepro = 1;
#endif
#ifndef SKIP_UNIVERSAL
int has_hex_character = L'\x0401';
int has_universal_character_4 = L'\u2118';
int has_universal_character_8 = L'\U00000401';
int const* has_universal_string_4 = L"\u2018\u03A7\u2060X\u2019";
int const* has_universal_string_8 = L"\U00002018\U000003A7\U00002060X\U00002019";
int has_\u03BA\u03B1\u03B8\u03BF\u03BB\u03B9\u03BA\u03CC\u03C2_\u03c7\u03B1\u03C1\u03B1\u03BA\u03C4\u03AE\u03C1 = 1;
const int \u03BA = 0;
int const*const has_keeps_token_boundary_for_universal = &\u03BA;
# ifndef SKIP_UNIVERSAL_MANGLE
/* When compiled, the two static variables that are defined here must
   result in two different symbols. There is no way to check this at
   compile time, unfortunately. So we have to check the object file
   by hand to determine this. */
int has_universal_good_mangle(int a) {
  static int volatile \u03ba;
  static int volatile _u03ba;
  \u03ba = !!a;
  _u03ba = !a;
  return \u03ba == _u03ba;
# else
int has_universal_bad_mangle;
# endif
# ifndef SKIP_UNIVERSAL_UTF8
double const π = 3.14159265;
double const* has_utf8 = &π;
# endif
#endif
/* Have checks for digraphs and trigraphs at the end, since they may
   mix up the pretty printing. */
#ifndef SKIP_DIGRAPH
/* check for the four "language" digraphs */
double has_punctuation_digraph <::> = <% 0 %>;
%: define HAS_HASH_DIGRAPH 1
enum { hasHashDigraph = !!HAS_HASH_DIGRAPH };
%: define DIGRAPH_STRINGIFY(X) %:X
char const has_digraph_stringify[] = DIGRAPH_STRINGIFY(digraph);
# if !defined(HAS_HASH_DIGRAPH)
#  error "The preprocessor lacks digraph %: support. Run test with -DSKIP_DIGRAPH to be able to see the other tests."
# endif
%: define HAS_HASH_HASH_DIGRAPH_(a, b) a %:%: b
%: define HAS_HASH_HASH_DIGRAPH HAS_HASH_HASH_DIGRAPH_(0, 1)
enum { hasHashHashDigraph = !!HAS_HASH_HASH_DIGRAPH};
/* This one here and the one in the trigraph section should be merged
   into one symbol. */
double has_hash_hash_interpretedCorrectly[hasHashHashDigraph];
# if !defined(HAS_HASH_HASH_DIGRAPH) || (HAS_HASH_HASH_DIGRAPH != 1)
#  error "The preprocessor lacks quadgraph %:%: support. Run test with -DSKIP_DIGRAPH to be able to see the other tests."
# endif
#endif
#ifndef SKIP_TRIGRAPH
/* Check for the eight "language" trigraphs. If this works and you
   run this through your preprocessor phase (usually with -E) this
   should, all of a sudden look like valid C code. */
int has_punctuation_trigraph ??(??) = ??< (0 ??' 1), (0 ??! 1), ??-0,  '??/0' ??>;
/* don't get confused by the syntax highlighting the ??' aint't too bad for that */
??= define HAS_HASH_TRIGRAPH 1
enum { hasHashTrigraph = !!HAS_HASH_TRIGRAPH };
??= define TRIGRAPH_STRINGIFY(X) ??=X
char const has_trigraph_stringfy[] = TRIGRAPH_STRINGIFY(trigraph);
# if !defined(HAS_HASH_TRIGRAPH)
#  error "The preprocessor lacks trigraph ??= support. Run test with -DSKIP_TRIGRAPH to be able to see the other tests."
# endif
??= define HAS_HASH_HASH_TRIGRAPH_(a, b) a ??=??= b
??= define HAS_HASH_HASH_TRIGRAPH HAS_HASH_HASH_TRIGRAPH_(0, 1)
enum { hasHashHashTrigraph = !!HAS_HASH_HASH_TRIGRAPH};
/* This one here and the one in the digraph section should be merged
   into one symbol. */
double has_hash_hash_interpretedCorrectly[hasHashHashTrigraph];
# if !defined(HAS_HASH_HASH_TRIGRAPH) || (HAS_HASH_HASH_TRIGRAPH != 1)
#  error "The preprocessor lacks hexgraph ??=??= support. Run test with -DSKIP_TRIGRAPH to be able to see the other tests."
# endif
#endif
 All Data Structures Files Functions Variables Typedefs Enumerations Enumerator Friends Defines
