P99
Modules | Macros | Functions
Macros that help in the handling of different kinds of types, forward declaring struct or union, and in handling enum. More...
+ Collaboration diagram for Type facilities:
Modules
 Type Names
 A bunch of types that are derived from the standard types.
Macros
#define P99_CONSTANT(T, NAME, INIT)   register T const NAME = INIT
 define a compile time constant NAME of type T with value INIT More...
#define P99_DECLARE_ENUM(T, ...)
 Declare a simple enumeration type. More...
#define P99_DECLARE_ENUM_GETNAME(T, ...)
 Declare a simple inline function to return strings containing the names of enumeration constants. More...
#define P99_DECLARE_ENUM_PARSE(T, ...)
 Declare a simple inline function to return the longest enumeration constants of type T found in a string. More...
#define P99_DECLARE_STRUCT(NAME)   typedef struct NAME NAME
 forward declaration of a struct NAME More...
#define P99_DECLARE_UNION(NAME)   typedef union NAME NAME
 forward declaration of a union NAME More...
#define P99_DEFINE_ENUM(T)
 Define the necessary symbols for a simple enumeration type. More...
#define P99_DEFINE_STRUCT(NAME, ...)
 Declare a structure of name NAME composed of the field declarations that are given in the remaining arguments. More...
#define P99_DEFINE_UNION(NAME, ...)
 definition of a union NAME More...
#define P99_DERIVED_TYPES(T)
 Declare trivial init and destroy functions for type T and its pointer derivatives. More...
#define P99_ENC(OBJ)   ((OBJ).p00_val)
 Access an encapsulated object. More...
#define P99_ENC_DECLARE(T, NAME)
 Encapsulate an object of type T in a new type called NAME. More...
#define P99_ENC_INIT(V)   { .p00_val = (V), }
 Initialize an encapsulated object. More...
#define P99_ENCP(OBJP)   ((OBJP)->p00_val)
 Access an encapsulated object through a pointer. More...
#define P99_EXT_ARITHMETIC_TYPES   P99_STD_ARITHMETIC_TYPES
#define P99_EXT_INTEGER_TYPES
#define P99_EXT_REAL_TYPES   P99_STD_REAL_TYPES
#define P99_LITERAL(...)   P99_SEQ(P00_LITERAL, __VA_ARGS__)
 Copy local variables back to the fields of same name inside a literal. More...
#define P99_PLAIN_TYPE(T)
 Declare trivial init and destroy functions for type T. More...
#define P99_POINTER_TYPE(T)
 Declare derived pointer types with endings "_ptr" and "_cptr". More...
#define P99_STD_ARITHMETIC_EXTS
#define P99_STD_ARITHMETIC_TYPES
#define P99_STD_BASIC_EXTS
#define P99_STD_BASIC_TYPES
#define P99_STD_CHARACTER_EXTS   c, hh, uhh
#define P99_STD_CHARACTER_TYPES
#define P99_STD_COMPLEX_EXTS   fc, dc, ldc
#define P99_STD_COMPLEX_TYPES
#define P99_STD_FLOATING_EXTS   P99_STD_REAL_FLOATING_EXTS, P99_STD_COMPLEX_EXTS
#define P99_STD_FLOATING_TYPES   P99_STD_REAL_FLOATING_TYPES, P99_STD_COMPLEX_TYPES
#define P99_STD_INTEGER_EXTS
#define P99_STD_INTEGER_TYPES
#define P99_STD_REAL_EXTS
#define P99_STD_REAL_FLOATING_EXTS   f, d, ld
#define P99_STD_REAL_FLOATING_TYPES
#define P99_STD_REAL_TYPES
#define P99_STD_SIGNED_EXTS   hh, h, i, l, ll
#define P99_STD_SIGNED_TYPES
#define P99_STD_UNSIGNED_EXTS   b, c, uhh, uh, u, ul, ull
#define P99_STD_UNSIGNED_TYPES
#define P99_STRUCT_LITERAL(TYPE, ...)   (TYPE){ P99_SEQ(P00_LITERAL, __VA_ARGS__) }
 Copy local variables back to the fields of same name inside a compound literal of type TYPE. More...
#define P99_STRUCT_TYPE0(TYPE, ...)   P99_FOR(TYPE, P99_NARG(__VA_ARGS__), P00_SEQ, P00_STRUCT_TYPE0, __VA_ARGS__)
 Transform the argument list into a list of lvalue for the fields of type TYPE. More...
#define P99_STRUCT_TYPES(TYPE, ...)   P99_FOR(TYPE, P99_NARG(__VA_ARGS__), P00_SEQ, P00_STRUCT_TYPES, __VA_ARGS__)
 Transform the argument list into a list of field types for type TYPE. More...
#define P99_STRUCT_UNUSE(TYPE, VAR, ...)   P99_FOR((TYPE, VAR), P99_NARG(__VA_ARGS__), P00_SEP, P00_STRUCT_UNUSE, __VA_ARGS__)
 Copy local variables back to the fields of variable VAR. More...
#define P99_STRUCT_USE(TYPE, VAR, ...)   P99_FOR((TYPE, VAR), P99_NARG(__VA_ARGS__), P00_SEP, P00_STRUCT_USE, __VA_ARGS__)
 Use the fields of variable VAR of type TYPE. More...
#define P99_UNUSED(...)   P99_SEP(P00_UNUSED, __VA_ARGS__)
 check if the list of expressions is syntactically valid but don't evaluate it More...
Functions
char const * bool_getname (bool p00_x)
Detailed Description
